BX23 FEL lift capability
   / BX23 FEL lift capability #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
A while back there had been a post in the attachments forum about some cheap forklift forks on Ebay. This came at just the right time for me because I already had it in my head to build a pallet fork attachment for the FEL on my BX23 so I could use it to move lumber / building supplies etc as I work on my house and build a garage/barn. Problem was these forks were heavy duty forklift style forks which weigh in pretty heavy - and the lift capability on the BX23 is not listed as being all that much ( 460 pounds ). Well I ordered the forks anyway and got them today - when I got them home I did a little experiment and loaded up the FEL bucket on the BX23 with a bunch of weightlifting weights to see just how much it would lift - well I found I could lift up 670 pounds from ground level to about 3 1/2 - 4 feet off the ground before it would not go anymore. So at first glance it appears the FEL on the BX lifts a bit more than I expected and I should be able to end up with a functional FEL pallet mover once I weld up a frame for the forks. Thought other people might want to know just how much a BX FEL can lift!
   / BX23 FEL lift capability #2
</font><font color="blue" class="small">( well I found I could lift up 670 pounds from ground level to about 3 1/2 - 4 feet off the ground before it would not go anymore.
)</font>
Cool! /forums/images/graemlins/cool.gif Just remember to use plenty of couterweight when lifting loads that heavy. /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
Thats what I bought that 600 + pound backhoe attachment on the back for! The rear tires are loaded too - plus when I did this test the tractor was actually headed down a slight incline in my backyard - I didn't feel any movement at all so I feel pretty confident I have more than enough rear weight to keep it safe. I had a rock in the FEL a week or so ago that it would not lift off the ground - which if I believe the results of this test would mean it was probably 700 pounds + , I managed to get it in the bucket and get the bucket off the ground to carry the rock some distance and the tractor felt just a little light in the back but not it was barely noticeable so I think with anything reasonable you can get in the bucket as long as the BH is attached you are ok.
   / BX23 FEL lift capability #4
</font><font color="blue" class="small">( Thats what I bought that 600 + pound backhoe attachment on the back for! )</font>
D'oh! Yup, I guess that would work! /forums/images/graemlins/grin.gif
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
Kubota RTV500 (A47384)
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
