BX23 FEL Hydraulic Hose Problem
   / BX23 FEL Hydraulic Hose Problem #1
kpmccarthy
Upon reattachment of the FEL the red coupler won't lock into place. Is there a trick or do I possibly have bad coupler?
   / BX23 FEL Hydraulic Hose Problem #2
You may have a little pressure on it. If you took it off when it was cool and it is warm now the fluid has expanded.
Wrap a rag around the coupler and use a screwdriver to push the "button" in the middle to bleed off the pressure. Should only be a few drops but use the rag and do NOT get fluid in your eyes.
Bill Tolle
That worked. Used a nut-driver handle to compress button. It was more than a few drops. Missed my eyes; but, got everything else. Anything that can be done to avoid that build up when disconnecting?
   / BX23 FEL Hydraulic Hose Problem #4
After you remove the FEL but before you disconnect the hoses, wiggle the loader control lever all over to 'relax' the hydraulics and let the FEL settle onto its support legs & buckets.
Basically, what I figure happens is the FEL is in a position where it is being supported by the hydraulics, not the legs. As the FEL settles over time, it pushes on the hydraulics, presurizing them.
   / BX23 FEL Hydraulic Hose Problem #5
Don't forget to turn the engine off to relax the hydraulics.
   / BX23 FEL Hydraulic Hose Problem #6
</font><font color="blue" class="small">( ........... Anything that can be done to avoid that build up when disconnecting? )</font>
Keep it cool by putting in the garage or you could just hose it down with ice cold water for a half hour. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2025 12V Diesel Pump and Hose with Meter (A50323)
2025 12V Diesel...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
