BX23 FEL Hydraulic Hose Problem
   / BX23 FEL Hydraulic Hose Problem #1
kpmccarthy
Upon reattachment of the FEL the red coupler won't lock into place. Is there a trick or do I possibly have bad coupler?
   / BX23 FEL Hydraulic Hose Problem #2
You may have a little pressure on it. If you took it off when it was cool and it is warm now the fluid has expanded.
Wrap a rag around the coupler and use a screwdriver to push the "button" in the middle to bleed off the pressure. Should only be a few drops but use the rag and do NOT get fluid in your eyes.
Bill Tolle
That worked. Used a nut-driver handle to compress button. It was more than a few drops. Missed my eyes; but, got everything else. Anything that can be done to avoid that build up when disconnecting?
   / BX23 FEL Hydraulic Hose Problem #4
After you remove the FEL but before you disconnect the hoses, wiggle the loader control lever all over to 'relax' the hydraulics and let the FEL settle onto its support legs & buckets.
Basically, what I figure happens is the FEL is in a position where it is being supported by the hydraulics, not the legs. As the FEL settles over time, it pushes on the hydraulics, presurizing them.
   / BX23 FEL Hydraulic Hose Problem #5
Don't forget to turn the engine off to relax the hydraulics.
   / BX23 FEL Hydraulic Hose Problem #6
</font><font color="blue" class="small">( ........... Anything that can be done to avoid that build up when disconnecting? )</font>
Keep it cool by putting in the garage or you could just hose it down with ice cold water for a half hour. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
2023 Kubota L2501D 25HP 4WD Utility Loader Tractor (A50322)
2023 Kubota L2501D...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
John Deere 4420 Combine (RUNS) (A50774)
John Deere 4420...
