Loader BX23 Control Valve part numbers
   / BX23 Control Valve part numbers #1
Couple of Achers
3rd rock from the sun
L4740
I have a BX23 and had to order new kits for the control valve detents. Not sure if that's the right verbage or not. But it's the things that screw into the bottom of the control valve that has springs and things inside. The one that controls the loader arms fit and worked perfectly. The float position was out of it and now that works. That was p/n YW232-91102.
The problem I have is the the one that controls the bucket p/n YW242-92101 does not work as it should and doesn't even look like the original equipment. It is called the detent regen. But unfortunately, that is all it does, it keeps the regen circuit active at all times. In other words, I don't have the quick dump any longer on the bucket. Which also means I will not be able to turn the front blade this winter unless I can get the correct part. My dealer is as stumped as I am. Every loader valve we looked at in the part manuals have the same part number. Does anyone know what the correct part number should be?
BX23 TLB' Loader is a LA210.
Thanks.
excavator trenching bucket- one bucket per lot (A56436)
excavator...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
1453 (A57192)
1453 (A57192)
New/Unused AGT Air Compressor (A57454)
New/Unused AGT Air...
2022 Behnke Trailer (A55973)
2022 Behnke...
