BX23 Brake questions
   / BX23 Brake questions #1
tshep
Richmond, VA
BX23 MLB
I have a little apply noise, so researching before I dig in.
In parts, I see 2 axle packs of discs that operate by, let's say cams, from the foot linkage.
Does replacing these REQUIRE pulling transmission up and out? All the way?
I see a piston operated clutch pack. I'll guess this system 'locks' up like a clutch would upon the first bit of engine on movement off neutral foot pedal, and thus only applies power when desired. Am I right? Is there any way to use this as a parking brake (apply piston with engine off?) Is it normally applied (locked up to engine) with engine off and no flow? (And thus already a parking brake like a car?)
I saw (on a maintenance site) reference to a PTO brake. Is there such a thing, mid or rear? Which parts pic? Disc based or mechanical?
THX and and all!
Did some 'work'.
Thought maybe it was odd sized wheels (getting over flat) so went back to 2 normal - no change.
It's the left side, and forward only. Apply at speed makes noise (rattle-ish) and locks up - tire slides.
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2020 John Deere 7230R (A53317)
2020 John Deere...
