Rear Blade BX2230 with 60" hydraulic angle rear blade
   / BX2230 with 60" hydraulic angle rear blade #1
HarleyScooter
Canton, Ohio
Kubota/ BX2230
BX2230 with 60\" hydraulic angle rear blade
I just finished adding a 2"X8" cylinder to the Woods rear blade.
Re: BX2230 with 60\" hydraulic angle rear blade
A top view showing the brackets
A close up picture showing the mounts including a second mount to use with the blade reversed.
Here is a picture with the blade reversed. I installed the blade cylinder mount on the centerline of the blade pivot which allows for a 30 degree pivot in each direction with 4" of the cylinders 8" stroke. I may install brackets on the York rake and use the same cylinder to angle it.
Scott
   / BX2230 with 60" hydraulic angle rear blade #5
Great job on that. And yes, duplicate the mountings for your rake!
Does the 2230 come with a remote hydraulic, or did you add it? I want to dig out the mod that ?? did to add one to my 2200 using non-Kubota stuff.
Ron
Ron, I added a Kubota two spool valve for the rear remotes about $500 I bought all the hose's and fittings locally. Junkman helped me with information on the installation. The valve is plumbed into backhoe hoses from a BX22/23 that I installed awhile ago. I still need to get a hyd top link when CCM gets them in.
Scott
   / BX2230 with 60" hydraulic angle rear blade #8
Very nice mod!
It really is an improvement over just being lazy because you can adjust the blade to whatever angle you want rather than being limited to the 2 or 3 angles drilled in the blade mount.
   / BX2230 with 60" hydraulic angle rear blade #9
Nice job, hope to do the same myself someday..
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A55852)
2002 Western Star...
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
