Rear Blade BX2230 with 60" hydraulic angle rear blade
   / BX2230 with 60" hydraulic angle rear blade #1
HarleyScooter
Canton, Ohio
Kubota/ BX2230
BX2230 with 60\" hydraulic angle rear blade
I just finished adding a 2"X8" cylinder to the Woods rear blade.
Re: BX2230 with 60\" hydraulic angle rear blade
A top view showing the brackets
A close up picture showing the mounts including a second mount to use with the blade reversed.
Here is a picture with the blade reversed. I installed the blade cylinder mount on the centerline of the blade pivot which allows for a 30 degree pivot in each direction with 4" of the cylinders 8" stroke. I may install brackets on the York rake and use the same cylinder to angle it.
Scott
   / BX2230 with 60" hydraulic angle rear blade #5
Great job on that. And yes, duplicate the mountings for your rake!
Does the 2230 come with a remote hydraulic, or did you add it? I want to dig out the mod that ?? did to add one to my 2200 using non-Kubota stuff.
Ron
Ron, I added a Kubota two spool valve for the rear remotes about $500 I bought all the hose's and fittings locally. Junkman helped me with information on the installation. The valve is plumbed into backhoe hoses from a BX22/23 that I installed awhile ago. I still need to get a hyd top link when CCM gets them in.
Scott
   / BX2230 with 60" hydraulic angle rear blade #8
Very nice mod!
It really is an improvement over just being lazy because you can adjust the blade to whatever angle you want rather than being limited to the 2 or 3 angles drilled in the blade mount.
   / BX2230 with 60" hydraulic angle rear blade #9
Nice job, hope to do the same myself someday..
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2007 CATERPILLAR 930G WHEEL LOADER (A51246)
2007 CATERPILLAR...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
