BX2230 hydraulic lines
/ BX2230 hydraulic lines #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I think this is normal but I wanted to ask a few others. I have a BX2230 with a Woods FEL and BH. Both removed but after abut an hour of mowing the return line that loops for the BH was pretty hot to the touch. Not hot enough to burn you but hot never the less. I assume this is normal since the tranny must warm up pretty good when your running around the lawn.
/ BX2230 hydraulic lines #2
Hydro fluid is usually at least 80 degrees warmer than ambient temperatures.
/ BX2230 hydraulic lines #3
That line will get hot....... hot enough to burn your hands if you hold them on it. The reason for this is that the fluid is constantly moving through the system. I wouldn't be concerned. The same thing happens with my BX22 and last summer when it was extremely hot (95+ degrees) and I was working the tractor hard, the hydro fluid started coming out the overflow from thermal expansion...
1996 International 4700 (A64127)
1996 International...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A64556)
2014 Hyundai...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
