BX2230 can't pull
/ BX2230 can't pull #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
BX2230 can\'t pull
I tried to drag my old septic tank on a piece of plywood across the level lawn to the field and found the weight to be overwhelming to the machine. I was kind of surprised. It has only 12 hours on it and perhaps it isn' broken in yet. I really have no idea what the tank weighs. I have included a shot for estimates. Am I expecting too much?
/ BX2230 can't pull #2
Re: BX2230 can\'t pull
Without seeing something next to the concrete it is hard to judge the size of the chunk, so I won't guess on the weight. But I've found when dragging heavy things, it is often easiest to drag them if the front end of the object is elevated, even if only elevated 1". The fact that you put it on plywood should help, but is there any way to elevate the front lip of the plywood for dragging purposes?
BTW, are you dragging the plywood with the grain or against it /forums/images/graemlins/wink.gif ?
/ BX2230 can't pull #3
Well at full throttle low range and full pedal it should it move or spin the tires. I drug a 12 x16 shed with mine over 1/2 mile on 4x4 skids. I agree with Bob that it is probably just digging into the ground. Try putting your chain or watever around that small end on the left hook the chain to the three point and lift it as high as the three point will lift and then try to drag it.
/ BX2230 can't pull #4
I would first make sure you are in low speed/gear (the turtle).
Also try 4 wheel drive. (lever near turtle wirh 4 wheels activated)
If that doesn't work, you can start by slowly moving it, step by step with the BH. I moved a 4 foot by 3 foot boulder this past weekend with the BX23 BH when the FEL wouldn't push it an inch.
/ BX2230 can't pull #5
Break down and purchase the right tool to do the job. You need a landscape rake, not a chunk of concrete. If you have an established lawn with low spots, get a load of loam and fill them till they are level. If it has heaves in it from the winter, then get a lawn roller. If you need to sink something in a pond, attach the concrete so it doesn't float to the top. The correct tool for the job is always best. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ BX2230 can't pull #6
</font><font color="blue" class="small">( Well at full throttle low range and full pedal it should it move or spin the tires. )</font>
Full pedal is the worse thing you can do. It puts you in the equivalent of a higher gear.
/ BX2230 can't pull #7
</font><font color="blue" class="small">( </font><font color="blueclass=small">Break down and purchase the right tool to do the job. You need a landscape rake, not a chunk of concrete. If you have an established lawn with low spots, get a load of loam and fill them till they are level. If it has heaves in it from the winter, then get a lawn roller. If you need to sink something in a pond, attach the concrete so it doesn't float to the top. The correct tool for the job is always best. Junkman </font>)</font>
<font color="black">I believe he's just trying to move it out of the way and Not use it
as a leveling device.
regards,
Steve </font>
/ BX2230 can't pull #8
did you try the flip, floppin' boogie? Use your FEL and flip it over and over...or push it...
It's hard to tell how big the concrete is, but appears to be pretty large.
/ BX2230 can't pull
Thanks all for the suggestions. I have taken Junkman's advice and got the right tool for the job... a sledgehammer /forums/images/graemlins/cool.gif. I refuse to open it right up until its has a few more hours on it. /forums/images/graemlins/grin.gif
/ BX2230 can't pull #11
Try wrapping a chain around it and fastening the end to the drawbar on your 3PT hitch. Then lift the hitch up, putting significant amount of weight on the hitch, and drag it away. This is how I move very large rocks.
/ BX2230 can't pull #12
As Jerry and others have said this may be expecting too much. That concrete likely is much heavier than you think and too much for a BX too drag.. I had to have a new set of 3 concrete steps poured for my back house door as the prior set was not done right. The concrete guy doing the work commented that his large kioti backhoe FEL tractor may have trouble removing the old concrete steps to the back of our tree line. Theses conrete block of steps looked about the same as your concrete chunk. When I have time I plan on breaking it up with a sledge hammer ans slowly disposing of it.
John Deere 1025R (A62177)
John Deere 1025R...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
24in excavator tooth bucket (A61307)
24in excavator...
2000 Ledwell 48ft. Step Deck Trailer (A64047)
2000 Ledwell 48ft...
SKIDDED PLAIN/WASTE WATER TANK (A63569)
SKIDDED...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
