Pat's Easy Change BX2230 and the Pat's Easy Change System
   / BX2230 and the Pat's Easy Change System #21
Re: BX2230 and the Pat\'s Easy Change System
Yep that's them.
Search in the Bota forums for stabilizer bars. As I recall, it was about $70. I ordered through tractor smart.
Links here describe in detail how to mod them to fit. It requires that you cut about one inch out of one side of each tube, to allow the arm to fit.
You can use some of the pins from your original setup to attach. I bought some ball detent 3/8" pins for the adjustment holes. Works slick.
Attached is a pic of mine.
Ron
   / BX2230 and the Pat's Easy Change System #22
I just ordered them from Tractor Smart, 59.60 shipped to me.
I will post the photos when I get them done. I am looking forward to my implements running true and not being loose as a goose.
   / BX2230 and the Pat's Easy Change System #23
Hey Danny,
Now you'll have the neatest setup any of us have come up with when you get the stabilizers installed, I got those before I got the quick hitch. When you get them installed, you can sell the spreader bar on E-Bay. /forums/images/graemlins/grin.gif here's a pic of the stabilizers when i first installed them
   / BX2230 and the Pat's Easy Change System #26
Don't be suprised if you go out some morning and find that your bx has these.
   / BX2230 and the Pat's Easy Change System #27
I got the email they are shipped..........yippee!
Can you tell my in laymans terms what I am going to do to these to make them work.
thanks
   / BX2230 and the Pat's Easy Change System #28
StevenW,
I don't have Pat's, but I do have the bagger for my BX1800 and I don't think it will work with Pats as it has a fixed length bar that mounts to the frame where the top link normally goes. Once Pats has the bottom out further, I think you won't be able to attach the top portion. Let me know if this proves to be wrong, because that is one of the main reasons I have decided against a quick hitch or Pat's.
That is a good point /forums/images/graemlins/confused.gif…It may make the top of the bagging system just lean in…not sure. I’ll let the forum know when I install it.
   / BX2230 and the Pat's Easy Change System #30
Danny,
The only thing that isn't just bolt on, is the end of the tube section, see circle on attachment. I put the tube in a vise and used a small angle grinder to cut the slot in the side of the tube, don't slot the wrong end of the tube like I did on one of them.
2022 Coras Predator Steel End Dump Trailer (A55314)
2022 Coras...
2010 Chevrolet Express Shuttle Bus (A55852)
2010 Chevrolet...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
Volvo A40D Off Road Dump Truck (A55314)
Volvo A40D Off...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A57024)
Ditch Witch 6510A...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
