Pat's Easy Change BX2230 and the Pat's Easy Change System
   / BX2230 and the Pat's Easy Change System #21
Re: BX2230 and the Pat\'s Easy Change System
Yep that's them.
Search in the Bota forums for stabilizer bars. As I recall, it was about $70. I ordered through tractor smart.
Links here describe in detail how to mod them to fit. It requires that you cut about one inch out of one side of each tube, to allow the arm to fit.
You can use some of the pins from your original setup to attach. I bought some ball detent 3/8" pins for the adjustment holes. Works slick.
Attached is a pic of mine.
Ron
   / BX2230 and the Pat's Easy Change System #22
I just ordered them from Tractor Smart, 59.60 shipped to me.
I will post the photos when I get them done. I am looking forward to my implements running true and not being loose as a goose.
   / BX2230 and the Pat's Easy Change System #23
Hey Danny,
Now you'll have the neatest setup any of us have come up with when you get the stabilizers installed, I got those before I got the quick hitch. When you get them installed, you can sell the spreader bar on E-Bay. /forums/images/graemlins/grin.gif here's a pic of the stabilizers when i first installed them
   / BX2230 and the Pat's Easy Change System #26
Don't be suprised if you go out some morning and find that your bx has these.
   / BX2230 and the Pat's Easy Change System #27
I got the email they are shipped..........yippee!
Can you tell my in laymans terms what I am going to do to these to make them work.
thanks
   / BX2230 and the Pat's Easy Change System #28
StevenW,
I don't have Pat's, but I do have the bagger for my BX1800 and I don't think it will work with Pats as it has a fixed length bar that mounts to the frame where the top link normally goes. Once Pats has the bottom out further, I think you won't be able to attach the top portion. Let me know if this proves to be wrong, because that is one of the main reasons I have decided against a quick hitch or Pat's.
That is a good point /forums/images/graemlins/confused.gif…It may make the top of the bagging system just lean in…not sure. I’ll let the forum know when I install it.
   / BX2230 and the Pat's Easy Change System #30
Danny,
The only thing that isn't just bolt on, is the end of the tube section, see circle on attachment. I put the tube in a vise and used a small angle grinder to cut the slot in the side of the tube, don't slot the wrong end of the tube like I did on one of them.
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2011 Ford F-150...
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2025 Kivel Bale Spear Skid Steer Attachment (A55851)
2025 Kivel Bale...
