BX2230 AND BLOWER
/ BX2230 AND BLOWER #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Looking for some advice on the BX2750 blower for the BX2230. I'd like to step up to a blower but not sure if its possible to put a front one on the tractor. I have a Woods FEL and BH on the tractor.
/ BX2230 AND BLOWER #2
I think it should be possible, the blower doesn't use any part of the loader frame and as long as the hydraulic quick connects are the same I can't think of anything else to prevent it.
Sent from my iPad using TractorByNet
/ BX2230 AND BLOWER #3
You will need a sub-frame and related drive shafts. The blower comes with a mechanical chute rotator but you can convert that to hydraulic for about $800 for a Kubota set up. Also with the sub-frame you can use a hydraulic angle blade. To switch front blade to blower is but a couple of minutes as they use a quick-connect "spade" assembly.
/ BX2230 AND BLOWER #4
Yea will work as long as you have the $$$$. Better figure a cab with a heater too while you are at it. You can use a power window motor to turn the chute for about $35. Figure about 2 hours to convert from summer to winter mode. IF we have the same winter as we had last year you will have a lot of use. Better buy now I recall last winter those that waited until winter could not find them.
/ BX2230 AND BLOWER #5
When I bought my snow blower off Craigs list, in the middle of the summer, the wife had her doubts. It sat in the garage for two years as the plow was adequate for the snow removal tasks. After last year, however, the snow blower proved its worth. I helped several neighbors that only had plows and had piled so much snow that they had no room left. The blower moves a lot of snow fast. If you don't have a cab invest in a ski jacket and ski pants makes the world of difference when the wind shifts and you get covered in snow :laughing:
2/14/14
2020 VOLVO EC140EL EXCAVATOR (A65053)
2020 VOLVO EC140EL...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2020 Takeuchi TL8R2 (A64126)
2020 Takeuchi...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
