BX2200 Steering problem
/ BX2200 Steering problem #1
kofronj
SE Wisconsin
Kubota BX2200
I've got a 1 year old BX2200 with 100+ hours on it. Yesterday while doing some yard cleanup, I noticed a steering problem:
While turning the steering wheel "gently", the tires would not move (left or right). So I'd be doing gentle turns, and continuing straight ahead. There was no undue force on the steering wheel, it moved freely and easily.
I could correct by moving the steering wheel more abruptly left or right---then the steering would kick in.
I have the repair manual, and the only thing I can come up with is low hydro fluid or air in the lines. I changed the hydro fluid at 50 hrs (Super-UDT), and the level seems to check fine (at least the to the best of my abilities, given that lousy dipstick). I suppose that there could be air in the system too; but I've put the steering far right or far left (so that the release valve runs for a couple seconds), and that hasn't helped. I don't know if there's any bleeding procedure to follow (the manual does say to 'bleed', but doesn't refer to a page number to discuss how). All the other hydraulic systems (transmission, 3-point) seem to be working fine (I didn't hook up the FEL to check it).
I'll call the dealer this morning, but I was wondering if anyone here had any ideas on what might be going on. Thanks!
Jim
/ BX2200 Steering problem #2
Sounds like a steering valve problem to me. If the valve is sticking and not opening you get no flow to the hydraulic steering cylinder, thus no turning. Just a thought. Let us know what your dealer says.
Good luck,
Clay
/ BX2200 Steering problem #3
Jim,
I expect you've got a case of the BX steering cylinder blues /forums/images/graemlins/frown.gif
I had the same problem last fall. My dealer said Kubota got a batch of bad steering cylinders from a supplier. Apparently the supplier left the machined cylinders sit outside prior to assembly where they got wet and slightly rusted inside. Just enough to cause the rod seals to wear and start leaking. Giving the wheel a good turn flows enough fluid to overcome and turn the wheels. It starts out slowly and just gets worse. They replaced the front cylinder on mine and so far so good /forums/images/graemlins/wink.gif
Your dealer should be able to take care of you,
Michael
/ BX2200 Steering problem #4
Yes there is a factory recall to replace the cylinder. Interesting that my BX2200 went in for the same problem just yesterday @ 142 hrs. Your dealer should know about the problem.
Ahhh, I just love this place... /forums/images/graemlins/laugh.gif
Talked to one of the mechanics this morning. He indicated the same thing (after checking to make sure that I didn't have the hydraulic lift pegged to the up position), and we'll try to get it scheduled.
I looked at the manual for doing this myself, and I think I'll defer...
Thanks again, everyone!
Update: After talking with the owner and a mechanic, they think I'm more than qualified to do the work (hahaha...). Knowing how busy this time of year is for them, and the fact that it's nearly an hour in transport time (one-way---and they'll have to do it), I'm more than willing to give it a shot.
I'll let you know how it turns out, in the end. But for now, I won't be doing any loader work close to any buildings! /forums/images/graemlins/cool.gif
/ BX2200 Steering problem #8
pcmem
Did your Dealer tell you what series of serial numbers the bad steering cylinder where installed on?
If not a problem when did you purchase and what serial number is yours.
Thanks
/ BX2200 Steering problem #9
The service bulletin # is PSB-2001-048 DATED 10/15/2001. I totally agree that this place has the greatest people in the world. I received my information from CARVER EQP some time back and feel delighted that I can help others.
/ BX2200 Steering problem #10
Pro_tel
Thanks!
My BX is starting to show the signs and since it's going in for "24 Month Survey Complaints" it's one more problem for the dealer to fix.
My dealer isn't the best and I always get the proverbal run-around. /forums/images/graemlins/mad.gif
Having the SB#, puts the ball in my court. /forums/images/graemlins/grin.gif
/ BX2200 Steering problem #11
rmc,
No they didn't. When I asked they said they (dealer) didn't know and that it was showing up in roughly half of the units they sold. They kept a kit on hand and fixed them as they showed up. Not sure what my sn is but it was bought fall 2001 if that helps.
If it is working fine I wouldn't worry about it,
Michael
/ BX2200 Steering problem #12
kofronj,
It isn't that difficult to replace. The hardest part is swapping the tie rod ends (because they like to be difficult /forums/images/graemlins/mad.gif ). You'll need some Kubota Super UDT or whatever you're running in the hydro to replace what spills out and fill the cylinder.
Good luck,
Michael
A happy ending for my tractor.
The parts came last Tuesday (FedEx), but I didn't have time to work on it until Friday evening/Saturday. I decided to follow the workshop manual instructions. Got the left hydraulic line off fine, couldn't get a wrench on the right side. So I removed the tie-rod nuts off, and (as predicted by pcmem), the right side came off fine, and the left wouldn't budge. Block of wood and a hammer---no luck. Finally gave it a rap or two with the hammer directly (after lots of wrestling and tugging), and it popped right out. Once I removed the brackets holding the cylinder to the frame, I could get the second hydraulic line off.
The tie rods were easily removed from the cylinder with large wrenches. Snap rings were removed too. I removed the hydraulic fittings from the old cylinder, and cleaned them (they had teflon tape on them) and put them on the new cylinder. Replaced snap rings, put tie rods back on, and hooked up lines quickly. Ran engine to check for leaks (none! /forums/images/graemlins/laugh.gif). Put everything back in place.
Steering is great again. It was probably about 2 - 2 1/2 hour job for me. I've had very limited experience working on tractors and cars, so this was a relatively good experience!
Thanks for the advice and tips, everyone!!!
Jim
UNUSED TAG BTB12518 - 18" PIN ON BUCKET (A64280)
UNUSED TAG...
UNUSED LOADER ATTACHMENT (A64280)
UNUSED LOADER...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
