Grading BX2200 problem pulling a blade
/ BX2200 problem pulling a blade #1
wpbarne
Middlesex County, VA
Kubota BX2200
I have a BX2200 with a 4 foot blade that I want to drag/grade our 100 yard long driveway with. The problem I have is the blade will not dig down but just skips over the top on any compacted dirt/gravel that needs to be redistrubuted. I have seen other tractors that the owners have added weights on the blade cross bar such as concrete blocks. Is this a good idea or will it harm the tractor in the long run?
Thanks for any input.
Ward.
/ BX2200 problem pulling a blade #2
Adding weight will help as the three point does not have any downforce except for the weight of the implement. After adding weight you might find you are digging too deep and have to lift the three point up a bit.
/ BX2200 problem pulling a blade #3
You should also check to see if you have your toplink adjusted properly. The toplink adjustment controls the angle of the blade in relationship to the ground.
Bill
/ BX2200 problem pulling a blade #4
Simple problem, hard compaction + lightweight equipment = many many passes to get it nice.
Or boxblade with the cutters down first, or drag whatever heavy thing you got layin around behind the blade for a few passes to break it up some, I have a nice heavy log i use sometimes.
/ BX2200 problem pulling a blade #5
A friend of mine had the same problem. He tried adding weight but it did not work well. After days of frustration he borrowed my middlebuster and made multiple passes to breakup the crown on the driveway. Then he gradeded the driveway with his backblade and applied an inch or so of crushed stone. The results were execelent. I think the boxblade may be the best solution.
JOHN DEERE 4110 TRACTOR (A64280)
JOHN DEERE 4110...
(5) 12' CARPETED BOAT GUIDES (A64280)
(5) 12' CARPETED...
2016 Ford F-150 4x4 Pickup Truck (A61573)
2016 Ford F-150...
2002 OilMens 76R 4,200 Gallon Commercial Truck Trailer (A61573)
2002 OilMens 76R...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
