bx2200/la211 loader problem
   / bx2200/la211 loader problem #1
frenchboy
kubota bx2200
When I raise my bucket I can't pull lever back to stop or nothing happens. I have to ease lever forward and bucket moves slowly with little power. Has anyone had same problem?
   / bx2200/la211 loader problem #2
Not sure I follow but make sure the lever for your 3PH is centered (in the neutral position). Sounds like pressure is bleeding off somewhere and in some of the older BXs, the 3PH lever doesn't always go back to neutral.
   / bx2200/la211 loader problem #3
How long has the situation been going on? Is it a sudden change?
Have you just had the FEL off?
That tractor/FEL combination is painfully slow at idle. How does it work at medium engine speed?
The loader works the same regardless of engine speed. Seems to be more likely a control valve issue to me. Is this control valve difficult to dissasemble and rebuild?
   / bx2200/la211 loader problem #5
Have you checked all of the hydraulic fittings? I had a similar
problem recently. A limb had pushed a hydraulic fitting apart. Loader
would dump and curl, but would raise very slow.
Hope this helps.
I will check in the morning. Thanks
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56436)
LIKE NEW 2023...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
