Mowing BX2200 60" mower deck
   / BX2200 60" mower deck #1
okie350
Mounds Oklahoma
L3010 & BX2200
The support bracket that holds the gear box on the mid mount mower cracked and broke where the bolt holes are, and i need to replace it (left side as your sitting on it) I have two questions;
1) isn't this a kind of a strange piece to have break? I ordered a replacement ($49), kind of expensive fo an "L" shaped piece of aluminum though.
2) while at the dealer I was going to order a some new blades for it since I was there, but they wanted $33 apiece for them, I need three:eek:. My question is; Is there a source you guys use other than the dealer to buy blades? $99 dollars seems a little steep to me. Or maybe Im just cheap:rolleyes:
Thanks for any help you can give
   / BX2200 60" mower deck #2
You can them anywhere other than a Kabota dealer that is, for under 20.00 I buy gators for 16.50 each on the internet. Sounds like this dealer is a little over the top with his mark-up:rolleyes:
Umm, where is anywhere, and how do you know what size / type?
   / BX2200 60" mower deck #4
I have never used Gators, but anytime I have used other than OEM blades they didn't hold up as well, so I only use Kubota or John Deere for my mowers. I would however be interested in hearing the experience of others in case there is an OEM equivalent out there.
   / BX2200 60" mower deck #5
I run Gators all the time and have seen no difference in longevity. I would Google lawn mower blades for Kabota tractors and give the the length of your blade. Do you have one off to measure length and hole dia.?
   / BX2200 60" mower deck #6
Try this link and download either the PDF by size or OEM mfg. I believe they have both standard and gator type for the BX decks, though not 100% sure. These are made by Oregon and I have them on my wheel horse. They are better than the Toro OEM blades in my opinion. Dont have them on the BX yet, but I will be switching at some point. I think Oregon makes a nice blade for the most part.
Once you have the part number, you can do a web search for the lowets price.
Oregon brand Fusion® and Gator Mulcher Lawn mower Blades
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A58017)
2019 PETERBILT 579...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
