Mowing BX2200 60" mower deck
/ BX2200 60" mower deck #1
okie350
Mounds Oklahoma
L3010 & BX2200
The support bracket that holds the gear box on the mid mount mower cracked and broke where the bolt holes are, and i need to replace it (left side as your sitting on it) I have two questions;
1) isn't this a kind of a strange piece to have break? I ordered a replacement ($49), kind of expensive fo an "L" shaped piece of aluminum though.
2) while at the dealer I was going to order a some new blades for it since I was there, but they wanted $33 apiece for them, I need three:eek:. My question is; Is there a source you guys use other than the dealer to buy blades? $99 dollars seems a little steep to me. Or maybe Im just cheap:rolleyes:
Thanks for any help you can give
/ BX2200 60" mower deck #2
You can them anywhere other than a Kabota dealer that is, for under 20.00 I buy gators for 16.50 each on the internet. Sounds like this dealer is a little over the top with his mark-up:rolleyes:
Umm, where is anywhere, and how do you know what size / type?
/ BX2200 60" mower deck #4
I have never used Gators, but anytime I have used other than OEM blades they didn't hold up as well, so I only use Kubota or John Deere for my mowers. I would however be interested in hearing the experience of others in case there is an OEM equivalent out there.
/ BX2200 60" mower deck #5
I run Gators all the time and have seen no difference in longevity. I would Google lawn mower blades for Kabota tractors and give the the length of your blade. Do you have one off to measure length and hole dia.?
/ BX2200 60" mower deck #6
Try this link and download either the PDF by size or OEM mfg. I believe they have both standard and gator type for the BX decks, though not 100% sure. These are made by Oregon and I have them on my wheel horse. They are better than the Toro OEM blades in my opinion. Dont have them on the BX yet, but I will be switching at some point. I think Oregon makes a nice blade for the most part.
Once you have the part number, you can do a web search for the lowets price.
Oregon brand Fusion® and Gator Mulcher Lawn mower Blades
