BX2200 4WD Click/Clunk noise and feeling
   / BX2200 4WD Click/Clunk noise and feeling #21
Ever bother to check the oil in the front axle? I still maintain one of the outboards is failing. I suggest you go to www.kubotabooks.com and download the shop manual for your tractor.
   / BX2200 4WD Click/Clunk noise and feeling #22
That's a differential, so make sure the play you see isn't just the driveshaft turning - unless you put it in 4wd to keep the shaft from turning. That wobbly u-joint doesn't sound good.
[edit to add] Just tested on my '24. Couldn't get it into 4wd w/out moving but it was sufficient to reach under and prevent the shaft from turning by hand. That done, the slop was only a couple of degrees as reported above.
Zoltan
   / BX2200 4WD Click/Clunk noise and feeling #23
Getting the front driveshaft / bearings / Ujoints tight/connected and aligned would be the first step - as if you "feel" it in the floorboard is likely the front shafts hitting something - there is a center bearing too - like a carrier bearing on the shaft in the diagram.
Update - Turned out the biggest culprit in my issue was a very loose front axle nut. I re-torqued it to spec and majority of my noise/feeling is gone.
   / BX2200 4WD Click/Clunk noise and feeling #25
Thank you for following thru and success in fixing your issue. So many times posters put out an issue/problem and never close the case.
Happy Tractoring!
2015 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2015 MACK ELITE...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2020 Autocar ACX Xpeditor T/A Front Loader Garbage Truck (A55852)
2020 Autocar ACX...
2012 Ford E-250 Cargo Van (A55852)
2012 Ford E-250...
CASE TR310 SKID STEER (A52707)
CASE TR310 SKID...
