BX2200 4WD Click/Clunk noise and feeling
   / BX2200 4WD Click/Clunk noise and feeling #21
Ever bother to check the oil in the front axle? I still maintain one of the outboards is failing. I suggest you go to www.kubotabooks.com and download the shop manual for your tractor.
   / BX2200 4WD Click/Clunk noise and feeling #22
That's a differential, so make sure the play you see isn't just the driveshaft turning - unless you put it in 4wd to keep the shaft from turning. That wobbly u-joint doesn't sound good.
[edit to add] Just tested on my '24. Couldn't get it into 4wd w/out moving but it was sufficient to reach under and prevent the shaft from turning by hand. That done, the slop was only a couple of degrees as reported above.
Zoltan
   / BX2200 4WD Click/Clunk noise and feeling #23
Getting the front driveshaft / bearings / Ujoints tight/connected and aligned would be the first step - as if you "feel" it in the floorboard is likely the front shafts hitting something - there is a center bearing too - like a carrier bearing on the shaft in the diagram.
Update - Turned out the biggest culprit in my issue was a very loose front axle nut. I re-torqued it to spec and majority of my noise/feeling is gone.
   / BX2200 4WD Click/Clunk noise and feeling #25
Thank you for following thru and success in fixing your issue. So many times posters put out an issue/problem and never close the case.
Happy Tractoring!
2010 CHEVROLET SILVERADO 3500 HD PICK UP TRUCK (A57880)
2010 CHEVROLET...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2013 Ford Transit Connect Cargo Van (A55852)
2013 Ford Transit...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2016 CATERPILLAR 336FL EXCAVATOR (A52707)
2016 CATERPILLAR...
