Anonymous Poster
- Joined
- Sep 27, 2005
- Messages
- 0
I think the 3pt on the BX2200 will actually work as intended if I can get the link balls all loose so maximum possible movement can be obtained without the come-along!
What do you guys recommend I use on the ball and sockets? I've always thought you were supposed to use the same stuff you use on trailer balls, that special oil that is thicker than 140W and sticky. I'm probably just going to put some thin oil on these until they get a titch looser. It's still a tight fit and I think I could design the arms better if I had Kubota's manufacturing team behind me. (healthy ego!)
It is nice to be able to just push the BX forward or back with one hand while hooking up! Can't do that with the old Ford!
