Snow bx22 snow blower?
/ bx22 snow blower? #1
frankd
Grantham, NH
Kubota L5240
anyone out there that can give me advice on what I should get
for a snow blower. live in NH in an area that usually gets a lot
of snow. It seems like I've seen a lot of posts for rear
mounted blowers vs the front unit. what are the pros and cons
for each, what are different models are out there and what should I expect to pay?
thanks,
frank
/ bx22 snow blower? #2
Frank
I have a BX2200 and I went with a rear 3 pt because of the cost. I paid $1000 for a Puma 54 " inch. They have a web site at http://www.pronovost.qc.ca/indexa.html. The front mounted unit was about $2200 from Kubota. I have a front end loader which I will keep on during the winter. So I can handle the snow drifts and the close work. I also looked at JRW- $1100, Farm King $1200;all were 54" inch units. http://www.sweettractors.com sells the Farm King, but is more then the $1200 I found it for in March 2002.
Guess it depends on how much driveway you have and if driving backwards is a pain in the neck to you. I do not have a cab so I know that will add to the fun this winter. Last tractor a Case 446 has a cab with a front mount snow blower was nice and dry and warm. I know I will end up buying a cap in the future, but this year I will see how it works.
I have not used the snow blower yet on the BX2200, hope to this winter!
Tom
/ bx22 snow blower? #3
The 50" kubota blower lists about $1400 at <A target="_blank" HREF=http://www.tractorsmart.com/>http://www.tractorsmart.com/</A>. Unfortunately, unless you already have the quick-tach system, you'll have to spend another 800-900 bucks. And you'll need the 4-way loader valve - you can probably work out a swap with the dealer if you have the 3-way. My dealer charged me $30 to trade.
I'd say a front mount would be the easiest/most comfortable to use -- but it's obviously more expensive!!
/ bx22 snow blower? #4
The Kubota setup with the quick-hitch and hydraulics cost me around $3000
/ bx22 snow blower? #5
I just bought a Kubota front blower from Service Motors here in Green Bay for $2,057. That included the quick hitch and extended pto shaft. I have an FEL so I did not have to buy a new control valve for the blower. Can't wait for the first snow to try it out. From what I have been told this sucker should really blow snow.....
/ bx22 snow blower? #6
Oh it does!!!
Hopefully this year we have a decent winter here that we can have a little fun. You're pretty close to me. I live in the Appleton area.
/ bx22 snow blower? #7
Ray do you use chains on your BX when you use the blower? I am debating wether to buy some....
Dan
/ bx22 snow blower? #8
So far I haven't needed them. I didn't have any traction problems with the turf tires last yr. I am planning on having the tires filled though.
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
Caterpillar 3126 Engine Service and Parts Manual (A63117)
Caterpillar 3126...
2009 Volkswagon Jetta Sedan (A61574)
2009 Volkswagon...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
