BX22 MMM Height Control
/ BX22 MMM Height Control #1
ehenry
Canton, ms
Kubota BX22 that was left to me by a dear friend. B7300 w/MMM
The mower deck height control knob is missing from my tractor so I've no clue where the top lock setting should be. The rod that the knob was on turns easily. My question is... which direction do I turn the rod to raise and lock the MMM arms at their top most setting? The owners manual doesnt say. I've turned the rod to the right 6 or 7 revolutions and there is no stopping point. It just continues to turn. Will it stop? Will it screw all the way in and stop if I keep turning? Am I turning it the wrong direction OR do I have a new problem?
The reason for the question is I installed a BXpanded skid pan and want it locked in place. I dont have a MMM for this tractor.
Thanks
/ BX22 MMM Height Control #2
It doesn't stop rotating. You'll have look under the tractor and keep trying different positions.
Thanks, Jesse B. I did notice when I turned the rod it seemed that I could feel clicks. Is that normal?
/ BX22 MMM Height Control #4
The height control is a spool with different notches cut in it. I would lower your mower down as far as it will go, then turn the knob left. When it hits the stop, raise the mower to the top and rotate about another 30 degrees and see if it stays up top as you lower it again.
I'd get a new knob as soon as you can though. Will make life easier.
If you can't figure this.out, I'll link you to my thread when mine was broken. Has a picture that might be helpful. Too hard to find it on my phone.
Thanks, Ray. I dont and wont have a deck on this tractor. At the position the rod is in now I'm thinking it lowers the arms to their lowest point. The bxpanded skid plate will always be on the tractor accept when I'm doing maintenance. I'll check it a click at the time.
I'll get a new knob at some point
Thanks again.
/ BX22 MMM Height Control #6
Thanks, Ray. I got it figured out. I was only two clicks off the top setting.
2008 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2008 Stertil Koni...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
