BX1870 strange starting issue
   / BX1870 strange starting issue #11
So it isn't really a true runaway. It revs itself up, but will sometimes shut down with the key on the first time, sometimes I have to quickly cycle the key on/off, and it shuts off that time. So far, it is 100% for shutting down on the first or second try. But yeah, a true runaway ends in a large repair bill!
My gut feeling is that it isn't crankcase oil, but something like a stuck fuel injector dumping fuel. The more I'm typing on this thread, the more I'm thinking it is possibly moisture in the fuel. For some reason it isn't gelling, but causing havoc in an injectors, sometimes...
An injector will not fail in a way to cause unintended acceleration. The injection pump having s stuck rack (older design) can do it. I do not know how common rail new tractor systems fail.
Dave
   / BX1870 strange starting issue #12
Would not think a BX is common rail now but still the regular injector pump. I would be looking at the injection pump/governor/shutoff lever area.
David
   / BX1870 strange starting issue #13
I think the fueling control for your injector pump is sticking in full fueled condition. Essentially the function that provides more fuel to maintain RPM selected by your hand throttle setting. When you turn off the engine the RPM falls waa-ay below the throttle setting and more fuel is automatically called for -- But not available due the shut solenoid. So, then later you start with the full fuel command in effect and stuck there because of cold.
Lubricative fuel additives may straighten this out.​
   / BX1870 strange starting issue #14
I tend to agree with this, could also be the governor is hanging up and calling for more fuel.
   / BX1870 strange starting issue #15
Yeah, like a governor. But I dont know what they call it on a diesel. :confused3:
That seems to fit the symptoms exactly. That could also explain the no-start after it does this. After it revs way up, the governor decides to cut as much fuel as possible, and essentially shuts it off entirely.
Just tried starting again today (30some degrees out), and it was fine. Definitely happens in cold weather only.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
PALLET OF CARBURETORS & PARTS WASHER (A58374)
PALLET OF...
Hose Reel (A55758)
Hose Reel (A55758)
2016 INTERNATIONAL DURASTAR 4400 (A58214)
2016 INTERNATIONAL...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
