Bx1860 won't even click when I turn the key
   / Bx1860 won't even click when I turn the key #1
casolorz
Wichita, KS
Kubota BX1860
So my bx1860 was doing the typical clicking sound it does before you turn it on but it wouldn't turn on. Battery is fine. PTO and pedals seemed fine. I looked at fuses and they seemed fine. Anyway, I then read some posts about PTO being touchy even when it is in the right position so I tried turning on the tractor and tried engaging the PTO and then put it back to see if it would help and I don't know what happened but not I won't even hear a click from the tractor, no lights come on, nothing. I checked the fuses and they seem fine but I don't have a tester.
Any idea what it could be?
   / Bx1860 won't even click when I turn the key #3
Follow black battery cable to frame. Remove and clean frame and cable contact points
   / Bx1860 won't even click when I turn the key #4
How old IS the battery and have you cleaned the terminals and frame ground lately or ever?
   / Bx1860 won't even click when I turn the key #5
After you're done cleaning all the connections and are sure the cables are tight if the problem is not resolved give serious thought to taking the battery to town and having it load tested. A battery can have full voltage and still not have the required energy to do the job.
   / Bx1860 won't even click when I turn the key #6
pull the pto lever back and HOLD it while trying to start. i assume you already made sure the hst pedal is centered. it doesnt matter if you are in the seat or not . everything else is not needed to start bx. I wouldnt worry about the battery since you can hear the clicking of fuel pump.
   / Bx1860 won't even click when I turn the key #7
While looking underneath your left fender, move the pto lever from engaged to resting position. Somewhere along that path, the lever should compress a switch, which gives continuity to the starter circuit. Sometimes they come loose, or quit making contact when in the off position. Are you familiar with using a meter ? If so, disconnect the switch under there, and use the meter to determine if the switch is working properly. As a testing aid, you could use a paperclip to temporarily short out the two leads that plug into that switch. Put the parking brake on, and see if it will start. If it does, with this test, then it is the switch that is either out of adjustment, or faulty. Please let us know what you find that was the problem.
   / Bx1860 won't even click when I turn the key #8
That is ONLY true if you measure the voltage at the battery terminals and it drops low when the battery is being used for something, like trying to energize the starter.
No need to go have the battery checked somewhere. Just put a voltmeter on the battery TERMINALS, NOT the cable clamps, and measure battery voltage when you try to start the engine. Bad battery? Voltage will drop very low. If voltage stays up, the problem is elsewhere, but not the battery itself.
   / Bx1860 won't even click when I turn the key #9
First, do the dash lights act normal and light up when you turn the key? Does the glow plug light go on when you turn the key a little further? If NOT do exactly what they guys are saying above about cleaning terminals, cable connections, etc. If YES, if the dash lights glow bright and 'normal' then you almost certainly have one of the VERY common problems with these small tractors. Namely insufficient voltage is reaching the primary (triggering) side of your solenoid.
I am very surprised the guys above have not mentioned it. A very common problem is getting the starter to turn when the battery and all other obvious things are in good order. The common problem (which by the way exists with other brands as well) is that you have many safety switches and interconnects between the starting key switch and the solenoid -- all of which provide a small voltage drop or chance for marginal connection. The fix many people use (Deere actually sells a kit for it) is to trigger an added small relay at/near the solenoid that provides a direct solid 12v to trigger the solenoid. That little relay is itself triggered by the same small wire coming from the harness that has already been through all the safety interlocks, etc. The manufacturers save a few pennies not putting one in at the factory.
To quickly and easily prove whether that is the problem, find the small wire leading from the harness to the solenoid. Take a clip lead or any handy jumper and be ready to momentarily apply a good solid 12v either direct from the battery or from the heavy cable connection on the other side of the solenoid to the small wire terminal on the solenoid using the clip lead. Just reach around and touch the "good 12v" to the small wire terminal while you have the starting key held in the spring loaded "to start" position. Assuming you already ran the glow plugs it will start right up. Anyway the solenoid and thus the starter are activated that way.
One of the circumstances that makes this quirky little problem so often misleading is the trigger side of the solenoid is getting ALMOST enough voltage to go but not quite. Thus many things you do like better ground cable connections, sanded connectors, cleaned up cables, on and on will provide a slight tiny improvement in voltage at the primary side of the solenoid -- enough to make you think you solved the problem and in a way you have IF IT KEEPS GOING long term.
Another VERY quick easy trick involving no wiring or extra wires is to apply a battery charger to your battery no matter what you think the battery condition is. Then try starting. Since the battery charger puts out typically 13.8v or so that will improve the voltage at the solenoid and it will start right up for you (if that is the problem which it probably is.)
Let us know how it goes.
   / Bx1860 won't even click when I turn the key #10
Been my experience that small tractor owners neglect battery connection maintenance and battery life, thinking wrongly that a 5,6 or 7 year old battery is fine when it's shot.
I replace the starting batteries in my large tractors every 3 years as a maintenance item.
Contrary to popular belief, heat is what kills a battery, not cold and vibration as well and tractor starting batteries are subject to both heat and vibration.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
Head Gate (A57454)
Head Gate (A57454)
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
New/Unused Fuel Delivery Tank with Pump (A57453)
New/Unused Fuel...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
