3-Point Hitch BX1860 question
/ BX1860 question #1
csmith3
Georgia
New Holland Workmaster 55 4WD Kubota BX1860
I've had a bx1860 for 2 or 3 years but never used the lift and just tried it for the first time and it only goes up, I can't get the lift arms to go down. Am I doing something wrong?
/ BX1860 question #2
Nothing wrong... The lift arms are only powered in the up direction. You need to hang something heavy from the lift arms to force them down.
/ BX1860 question #3
They should drop (if your talking about the 3ph arms on the rear of your tractor) when you push the lever to go down because of their own weight. They do not power down, only power up. If you've never used them then they may be gumed up with dirt or something. Push the lever down while standing on one and it should drop and after doing it a couple of times it should drop on its own with out you standing on it. Maybe spray with some WD40.
/ BX1860 question #4
is the flow control on the right side of your foot open?
/ BX1860 question #5
Read your owners manual there should be a valve that controls the rate of speed the 3 point works. Maybe closed up
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
78in Dual Cylinder Brush Grapple Skid Steer Attachment (A59228)
78in Dual Cylinder...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 4x4...
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab Pickup Truck (A59230)
2018 Chevrolet...
