bx1860 MMM mulching?
/ bx1860 MMM mulching? #1
casolorz
Wichita, KS
Kubota BX1860
I have a bx1860 with a RCK54P-23BX MMM. I have mulching blades on it but I am starting to think I need something else for mulching. Should I at a minimum have something covering the side so grass doesn't fly out? Not sure if it matters but I have gator mulching blades (which had to be drilled to fit).
/ bx1860 MMM mulching? #2
No answer, but I'll add to the questions...
My GR2120 was delivered with a 54" deck with mulch kit. I wish it didn't have the discharge blocked off. It does a lot of clumping on that side, and makes for a poor looking lawn.
A better deal would be the setup I had on my Deere 425. It had an adjustable block off so it could be set to discharge just enough to avoid clumping.
Does Kubota have such a thing? Or anyone modified a Kubota mulch kit?
Z.
/ bx1860 MMM mulching? #3
I believe that for the precision deck the add-on piece essentially creates 3 blade chambers that are separate from one another. It goes beyond just blocking the discharge chute.
I have a regular cut deck. My mulch kit is very different, but I am very satisfied with it.
/ bx1860 MMM mulching? #4
I have a mulch kit on my 60" BX deck. The kit came with blades, and a bunch of steel parts that are more or less baffles and block offs. It works pretty well and I like it. It wasn't cheap, it seemed like it was around $300.
Well this is odd, I never got the notifications even though I was subscribed to the thread.
Thank you for the replies, I guess I'll start looking for the kit.
Unused 2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
Unused 2025 HT360W...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
20' DOUBLE AXLE INDUSTRIAL TRAILER (A59823)
20' DOUBLE AXLE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A59230)
2007 Oshkosh...
2020 Kubota RVX900 4x4 Diesel Utility Cart (A59228)
2020 Kubota RVX900...
