bx1850 oil light
   / bx1850 oil light #1
drag_slick
ND
New Holland T2220 SuperSteer
Went out to do a little spring (hopefully :) ) cleaning on the road today, little snowblowing and pushing with the FEL. Everything operated as normal.
Pulled it back in the shop and when I idled it down all the way, 1350-1390 rpm on the display, the oil light started to flicker. I shut it off, checked the oil level and it was fine. Started it up again, still flickering, bumped the throttle up, and even going up 100-200 rpm, it goes out, so just when I idle all the way down does it dimly flicker. :confused:
Outside temp was about 35 degrees and we did get sprinkled on a little bit, maybe something got a wet? Oil was changed last fall at 270hrs and I've got 310 on it now, using Amsoil 5-30 synthetic, same oil I've used since the 50hr oil change. I'm also still running straight #1 diesel since we're just warming up from another freezing winter.
Thoughts?
   / bx1850 oil light #2
drag_slick,
The first thing I would do is to remove the sender and put a pressure gauge in it's place. Most engine sending units turn on the light at only a few PSI. Most likely the sender is bad, but the gauge will verify that. With cold oil, you should see a fair anount more than 10 PSI at idle. Anything less than that and I would be worried. You may have a stuck pressure releif valve if the pressure is low.
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
2014 FORD F-350 SUPER DUTY (A52472)
2014 FORD F-350...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
Teeno Snow Skis (A51573)
Teeno Snow Skis...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A52472)
2008 STEPHENS...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
