BX1500 Tranny Issue??
   / BX1500 Tranny Issue?? #1
jerkyboy
Upstate NY
Today I moved about 5 yards of crusher run and I noticed that my tractor "shudders"/slips(?) when I'm going to pick up material from the pile, and it also does it when I'm moving around on the pad that I'm making. I've never had this shuddering/slipping issue before. It's comparable to wheel hop but the tires aren't spinning. I checked the trans fluid and it's fine and doesn't smell at all. My tractor has 480 hours, been meticulously maintained, and I have my leaf bagging system, mowing deck, and FEL on so maybe that's (too much weight) causing the problem??? Any ideas:confused:
I hope its not this :
http://www.tractorbynet.com/forums/kubota-owning-operating/162734-help-mighty-mouse-nibbled-kryptonite.html --Another guy had something similar recently and I think his turned out to be the proportioning valve.
larry
Thanks for the link to your old post. After reading it, I'm thinking (and hoping) that my tires may be slipping on the rims because they are fluid filled and I do have a lot of weight on the tractor with the bagging system and mowing deck on too. I'm having absolutely no hydrualic issues whatsoever; I've been lifting full buckets of crusher run without it skipping a beat. The shuderring does happen anytime there is a lot of resistance regardless of going forward or reverse and it happens in low and high. I'll change the filter tomorrow if I can get one and also check for the tire slippage.
Just curious if you ever got your problem resolved, and if so, what it was and how much it cost. Thanks for the great info.:thumbsup:
   / BX1500 Tranny Issue?? #4
I had the transmission replaced because cost would have been almost as much to remove, fix and reassemble as it was to just change out. And it would have been a worn trans. I kept the old trans and look forward to checking it out when I have the time.
larry
Tranny replaced!!! Ouch.....I hope that's not my problem as my tractor has less than 500 hours. If it is my tranny, what should I expect the bill to be?
   / BX1500 Tranny Issue?? #6
around $1500
Thanks, when I figure it out I'll report back.
   / BX1500 Tranny Issue?? #8
I know it sounds like a stupid question, but do you have 4WD engaged? If you do and you are on a hard surface, the front wheels could be putting the drivetrain in a bind which would cause a shudder or "bucking" effect.
Yup, does it in 4WD too. Tomorrow I am going to take the FEL off and mow the lawn and I'll report back afterwards. I also plan on changing the tranny fluid/filter and cleaning the screen next week.
   / BX1500 Tranny Issue?? #10
This is what I was wondering as well, I think you misunderstood his question. He was stating that having it in 4WD on a hard surface can cause this type of problem because the front wheels and the back wheels are working at different ratios when the front tires are turned especially. He wasn't asking if it does it in 4WD, he was stating that if you were in 4WD it could cause this problem. So the question would be does it happen in 2WD?
Pallet of (15) 10 Lug Misc Wheels (A48837)
Pallet of (15) 10...
2012 DODGE Ram (A46684)
2012 DODGE Ram...
2017 GMC Yukon XL 4x4 SUV (A46684)
2017 GMC Yukon XL...
2010 Cadillac SRX SUV (A46684)
2010 Cadillac SRX...
Coral Panels (A49339)
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A45679)
2015 FREIGHTLINER...
