Oil & Fuel BX1500 stops when hydraulic system activated
/ BX1500 stops when hydraulic system activated #1
b4gmadeley
Mohnton.Pa
kubota BX1500
The engine will run all day without a miss, but when i put in gear and use bucket, misses and kills motor sometimes. any one have a idea whats wrong, Thank You.
/ BX1500 stops when hydraulic system activated #2
Have you checked the fuel filters. My BX would idle all day but would not do any work when the fuel filter was getting plugged. Does your BX1500 have two filters? One is located under the tractor before the electric fuel pump and this is the one that always plugged on my BX.
thanks, i will do filters again, they may need to be changed more often than i thought.
/ BX1500 stops when hydraulic system activated #4
If it is not the filters then I would think it is a safety switch. Seat occupancy?
AEREATOR (A58214)
AEREATOR (A58214)
2024 JCB 35Z (A60462)
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
CFG Industrial MH12RX (A60463)
CFG Industrial...
(2½...) 24"x20' PVC Pipe (A60463)
(2½...) 24"x20'...
