Oil & Fuel BX1500 stops when hydraulic system activated
   / BX1500 stops when hydraulic system activated #1
b4gmadeley
Mohnton.Pa
kubota BX1500
The engine will run all day without a miss, but when i put in gear and use bucket, misses and kills motor sometimes. any one have a idea whats wrong, Thank You.
   / BX1500 stops when hydraulic system activated #2
Have you checked the fuel filters. My BX would idle all day but would not do any work when the fuel filter was getting plugged. Does your BX1500 have two filters? One is located under the tractor before the electric fuel pump and this is the one that always plugged on my BX.
thanks, i will do filters again, they may need to be changed more often than i thought.
   / BX1500 stops when hydraulic system activated #4
If it is not the filters then I would think it is a safety switch. Seat occupancy?
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
