fih25 said:I have had my bx 1500 for 3 years and have never had the 54" deck bog down. I also use it in the fall to help with leaf removal, since I don't have a sweeper, etc. I just start next to the trees with the deck up and then make circles, until I have the leaves in a pile, it mulches/blows the leaves into a pile and as the leaves pile up the mower keeps cutting /blowing them with no bogging down.I then load up the leaves in a cart and the loader and haul them away into the fields and dump/spread them out. Sure beats raking them all. I only use a rake to pick up the leaves to put them in the cart and loader bucket.
SPYDERLK said:How fast do you go?? Mine seems to run fine, but the 54 deck will bog it in average to thick grass unless I mow in low range, or significantly back off in hi range. Even in low range it will not mow uphill at full pedal.
larry
Did you have a 54" mower? I run full throttle to mow and it will mow anything if you go slow -- even 2" trees. However, I always have to go below full speed in low range for thick grass even if its not very high.kevinj said:I used to have a 1500 and it performed well. Are you running full throttle??? I can see bogging on a serious hill but not on a normal lawn, especially in low range where the thing is a tank.
SPYDERLK said:Did you have a 54" mower? I run full throttle to mow and it will mow anything if you go slow -- even 2" trees. However, I always have to go below full speed in low range for thick grass even if its not very high.
larry
