BX won't start!
   / BX won't start!
Re: BX starts!
She runs! I did check the fuse.......but I checked it again and magically it was blown! Changed the fuse with a slightly larger one because that's all I had at the time (25 AMP). Thanks, Jim
   / BX won't start!
Re: BX won\'t start!
Kub,
She runs. As I said in another post....the fuse was blown. It was really hard to see without a bright light. I put a 25 AMP fuse in, cuz that's all I had. Do you think that's going to be a problem? Maybe I should just get a 20 AMP and be done with it.
Thanks, Jim
   / BX won't start! #13
Jim, put the 20 back in as soon as you get a chance. That's just the right way to do it. Hopefully it was just an isolated incident and you won't have anymore problems. Just keep in mind fuses blow for a reason. What color wire did you tap into for the lights, may be related.
   / BX won't start!
Kub,
Thanks, I'll get a 20 tomorrow. I just fired it up to make sure that was definitely the problem and then shut it down less than a minute later.
I used the AUX wire (under the seat) for the lights. I believe this is the wire to use for lights.
Glad she's running again. I was starting to get worried.
-Jim
SKID STEER GRAPPLE BUCKET (A58214)
SKID STEER GRAPPLE...
Kubota M108S (A53317)
WATER TRAILER (A58214)
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Hose Reel (A55758)
Hose Reel (A55758)
