BX-Wheels will not spin-Normal?
   / BX-Wheels will not spin-Normal? #1
Mike_Lipke
Kubota BX1500
I just got a used (67 hours) BX1500 with 48" deck and a new FEL.
Plenty of power for mowing and FEL work, but not a lot of power to the wheels.
First time I wondered was when I was moving the tractor for the first time in the driveway. Tried to go from the driveway to the grass, and had to go over a landscape timber that is about 3" high. I was in high range, mower off and up, FEL up about 18", in 4wd. Drove tractor up to the edge of the driveway (gravel) very slowly til the front wheels were agains the 3" timber and pushed the speed control pedal forward. Nothing doing. Tractor just sat there trying, but no go. Engine did not slow down, wheels would not turn. I put it in low range and it climbed over the edge.
Later, I was pushing against an old rotten 4" stump with the FEL. This time I was in lo range, 4wd, and on damp grass. Full engine rpm, pushing and lifting with the bucket. The stump did break out fine by tilting bucket up, but what puzzles me is that again, the tires would not spin on the grass.
Is this normal? On my old cub cadet with HST, either a wheel would spin, or the engine speed would drop down quite a bit as the load was applied. With the BX, it seems like the engine is not even "aware" of the load. Dealer is not sure if this is normal without comparing it to another BX1500 on gravel.
If they all are like this, that is fine. But it seems like either the pump is weak, hydro oil is too thin, or there is a relief valve set to unload at too low a psi.
Please don't think I just want to spin the tires, but it doesn't seem right.
Thanks in advance for sharing your experience.
   / BX-Wheels will not spin-Normal? #2
This may seem like a dumb question and I in now am trying to insult you. You do know that the more you push down on the pedal the higher the effective gear ratio will be in the transmission? There have been several new owners here that have tried to use the pedal like an accelerator pedal, which you can't.
No insult taken. I understand what you are saying. But I would think that this tractor would have enough "push" to spin a tire on grass if it were unable to move whatever it was up against, especially with just a little pedal pressure.
   / BX-Wheels will not spin-Normal? #4
I don't know how much power a BX should have in high range. I am sure one of our BX owners or a dealer will post before long.
   / BX-Wheels will not spin-Normal? #5
Hard to say....
My L3130 will stall pushing the peddle to the floor unless it could spin the tires. My Craftsman 18hp riding mower will load the motor slightly and the hydro just makes noise.
   / BX-Wheels will not spin-Normal? #6
Hi gear doesn't have much torque on these tractors, and when trying to drive forward and lift with the bucket the power is shared between the two.
Guy
I found that out when trying to go over the 3" curb. But I was in low range when I was using the FEL, and had them just sit there trying to turn on the grass.
   / BX-Wheels will not spin-Normal? #8
Mike,
I have a BX22 and have experienced the same thing you did. The tractor doesn't seem to get much torque to the wheels when presented with certain obstacles. I think this is normal for a Hydrostatic drive transmission. It doesn't seem to make sense that the machine won't spin the tires in certain situations but I believe this is engineered into the drive system so the transmission doesnt self destruct. The only time I have spun the tires on my BX is in deep loose gravel (12"+) and mud and that was in 2wd. I dont think I ever saw the tires spin in 4wd except in snow. One other thing, you will be surprised at the traction you will get in shallow gravel with the bar tires (if you have bar tires). They bite pretty good and if you can get the rears to spin the whole machine jumps up and down due to the tires trying to bite. In closing, I think what you experienced is normal and I wouldn't lose any sleep over it.
Jeff
Well, thanks. The thing is made so well that it is probably normal behavior if yours does the same. I sleep fine, but I thought that it might have enough power delivered to the wheels that it might be able to drag something heavy out of the woods. My mother-in-law, for instance. I have turf tires, btw.
   / BX-Wheels will not spin-Normal? #10
My BX2200 up against a tree in 4 wheel low will spin the tires on dry grass with just a bit of throttle. In fact I want to say I've even had the rears locked in and still spun them well at least 3 of them, im not sure if both fronts spin in 4 wheel or not.
BTW I have Turfs on her.......
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
10 ft Wrought Iron Fence (A56859)
10 ft Wrought Iron...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
