Tires BX valve stem leaking air
   / BX valve stem leaking air #11
Kubota tire valve stems. Been there, done that.
Mine were so dry rotted that one broke off when I tried to remove the cap.
   / BX valve stem leaking air #12
Mine were so dry rotted that one broke break off when I tried to remove the cap.
Mine just did that. Right now my BX23 has the rear end sitting up on blocks because the stem broke off - all the air leaked out - and then beet juice starting draining out all over the ground.
Besides taking it to the dealer - how much of a pain is it to unseat the rim and get a new tire valve in? I tried forcing it in from the outside, but I think that's a no go. Now I'm thinking I take the tire off, lay it down on the ground (so the beet juice doesn't all drain out) - and the try to get my hand in there and push the new valve stem thru.
How much of a pain is it to unseat the tire - any good tips?
How much of a pain is it to reseat the tire - any good tips?
   / BX valve stem leaking air #13
Breaking the bead is a real pita with hand tools I even went to trying the backhoe to use down pressure to break the bead,finally used the dolly leg on my 80,000 pound trailer , worked like a charm...replacing the tire valve is quite easy once the bead is broken and all you need to re seat bead is air
   / BX valve stem leaking air #14
I had same problem with my BX24 with rears. metal part of threaded tire stem just twisted inside when I went to check tire pressure and leaked. I ended up replacing both stems.
took my BX24 rear wheels in to the local tire shop...
installed 2 new stubby valve stems... took 10 minutes and $10 cash.
Pete
   / BX valve stem leaking air #16
They make a tool to replace valve stems from the outside. No need to break down the tire from the rim.
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
Swamp Buggy (A49346)
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2022 McConnel TRAXX RC28 Remote Controlled Slope Mower (A51691)
2022 McConnel...
