Tires BX valve stem leaking air
/ BX valve stem leaking air #1
uglyboywith11fingers
Gold Member
Georgetown, Ontario
2007 BX24TLB, 1998 TG1860G
Here's a new one, maybe somebody else has encountered this...
I took the snowblower off my BX24 today (17degC/63F in Southern Ontario) and thought I'd check tire pressure. I started unscrewing the valve cap on one rear wheel, and it was turning but not coming off, thought I could hear air leaking, then I realized the whole valve stem was turning in the rim... with air leaking around the valve stem. I had to hold the valve stem with one hand and turn the cap with the other to get it off. Tire pressure was just under 20 psi. I had to rotate the valve stem carefully to find a spot so it stopped leaking. I checked the other rear wheel and that valve stem rotated in the rim too.
I've had my BX24 since Sept 2011 and have to add air to the right front every month, but the rears have not been leaking.
The valve stems rotate quite easily... I'm thinking maybe the rubber has gotten hard or just poor quality valve stems.
I have not verified why my right front loses air... just figured it was the notorious rim leak.
What do you fellas make of this ???
/ BX valve stem leaking air #2
I had the same problem on my RTV 900. I Replaced mine with metal valve stems. Think my RTV was on the lot for a bit before I bought it.
/ BX valve stem leaking air #3
Bizarre. I couldn't imagine the stem would rotate with that much pressure in the tire. I'd take that back to the dealer since it's so new, let them change the stems for you.
BeezFun... wishful thinking !
I should have said I bought the BX24 used last Sept. It was sold new in Dec 2007, has about 260 hours, always garage kept.
I'll just take the wheels in to a tire shop... no prob since they're not loaded...
Need them to look at that slow leak in the front tire also.
I have put new valve stems in wheelbarrow wheels... they were a snug fit and for sure would not rotate even without air pressure behind it. Don't know if these are inferior valve stems or the holes in the wheels too large.
/ BX valve stem leaking air #5
There are different size rim holes and valve stem diameters. Sounds like yours are mismatched. When I install a valve stem, the fit is very tight, no possibility of hand twisting even without any air pressure. You just need a different stem. You can do this yourself, or have someone else do it. Not too hard, does not require removing tire from rim, just deflating and breaking seal to get to the stem hole from below.
/ BX valve stem leaking air #6
My Bx24 had crappy tire valves from new. Really crappy, soft rubber and leaky. I swapped them all out for metal ones and all is well.
/ BX valve stem leaking air #7
I like the metal valve stems in my on-road vehicles. Not too sure about on a tractor.
It would seem that the rubber ones would take less damage from branches, etc. since they would flex out of the way.
Can't say for sure. A lot of my work is around branches and slash so driving through such debris will kick up chunks into the tires and rims.
Also, if you have a tendency to sink the tires in mud (not that I know anyone who does :ashamed:) the rocks and mud will build up in the rims as the tire spins.
Just another random thought.
/ BX valve stem leaking air #8
I had a leaky one on mine, the front. It leaked and went flat when my son was moving a big pile of sand with it and it ruined the tire.
/ BX valve stem leaking air #9
There's at least one other thread around here about Kubota valve stems.
I've had two on my BX24 just crumble. Fortunately there wasn't any other damage done, but what a PITA.
Z.
/ BX valve stem leaking air #10
Kubota tire valve stems. Been there, done that.
Mine were so dry rotted that one broke break off when I tried to remove the cap.
/ BX valve stem leaking air #11
Mine were so dry rotted that one broke off when I tried to remove the cap.
/ BX valve stem leaking air #12
Mine just did that. Right now my BX23 has the rear end sitting up on blocks because the stem broke off - all the air leaked out - and then beet juice starting draining out all over the ground.
Besides taking it to the dealer - how much of a pain is it to unseat the rim and get a new tire valve in? I tried forcing it in from the outside, but I think that's a no go. Now I'm thinking I take the tire off, lay it down on the ground (so the beet juice doesn't all drain out) - and the try to get my hand in there and push the new valve stem thru.
How much of a pain is it to unseat the tire - any good tips?
How much of a pain is it to reseat the tire - any good tips?
/ BX valve stem leaking air #13
Breaking the bead is a real pita with hand tools I even went to trying the backhoe to use down pressure to break the bead,finally used the dolly leg on my 80,000 pound trailer , worked like a charm...replacing the tire valve is quite easy once the bead is broken and all you need to re seat bead is air
/ BX valve stem leaking air #14
I had same problem with my BX24 with rears. metal part of threaded tire stem just twisted inside when I went to check tire pressure and leaked. I ended up replacing both stems.
took my BX24 rear wheels in to the local tire shop...
installed 2 new stubby valve stems... took 10 minutes and $10 cash.
Pete
/ BX valve stem leaking air #16
They make a tool to replace valve stems from the outside. No need to break down the tire from the rim.
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2017 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2017 GMC Sierra...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
