BX & Toolbox
/ BX & Toolbox #1
DaninGreenBay
WI, USA
Kubota 2200
Dear fellow BXers..... I need to mount a small toolbox on my BX2200 to store some tools, lynch pins, etc in. Have any of you installed one yet on your BX? If so where did you end up mounting it? I was thinking of hanging it on the ROPS but there probably is a better place. I usually have my FEL on the front so not much room up there.....
/ BX & Toolbox #2
I ended up buying a Cratsman toolbag. I put it on the deck, right in front of me, between my feet. It's out of the way and I can grab it and take it with me if I need it. Its conveniant and cheap...cost me about $16.
/ BX & Toolbox
Thanks Charlie. I will drop by Sears tomorrow to take a look....
/ BX & Toolbox #4
I found a small red hip roofed tool box at my local Aubuchon Hardware store that I monted behind the seat of my BX1800. It is large enough for a couble of wrenches, pliers, a small ball pean hammer, pins garden shears etc. I drilled two holes in the bottom of the box trough the sheet metal behind the seat to mount it and it works really well.
/ BX & Toolbox #6
I Just purchased a new BX2200, with FEL and 54" MMM, and a box scrapper. I needed a tool box to keep a chain and a few tools in, so I got a piece of 4" thick walled pipe and some end caps and clean out plugs and glued them together. Then i strapped them to the insides of the ROPs . There out of the way and dont look bad either.
/ BX & Toolbox #7
I carry a tool box in my weight box (see attachment) that goes on the 3 point hitch. It will easily hold a metal toolbox plus you can carry bigger tools like sledgehammer, rakes, etc.
You ought to be using a weight box anyway, the BX2200 really needs rear ballast with the FEL.
/ BX & Toolbox #9
Al, when I bought mine it was delivered with the tractor. I think it is a 'real' farm implement as it is well made. I bought the tractor from Bob Wolff of Woodbury Tractor 203 266-4845. Compared to the price of it it would not be worth it to ship because it is heavy, but Bob might be able to tell you the brand so you could find one locally. There was no brand marking on it, maybe he has a local machine shop build 'em who knows.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A64194)
2015 SkyJack SJ86T...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2015 Ford Fusion Sedan (A64557)
2015 Ford Fusion...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
