BX Tires going flat
/ BX Tires going flat #21
My first BX2660, no issues with turfs. Even the R-4’s were fine for years. Now, my current BX2670 had issues the first year. Got fed up. Tubed them. Last month, one went flat. Dealer said “Don’t tube it. Seal the bead”. So far so good. One tubed, one sealed. As soon as I can swing it, I’m getting a set of R-4’s. The turfs are good for grad, and grass only.
I should clarify... my experience is with R4s. Can't speak for turfs.
/ BX Tires going flat #22
I will say it again... TUBES... and be done with it.
Ha ha! I too will say it again.
Get your tires foam filled and forget punctures and leaks forever!
About 15 years on mine to date and absolutely no regrets...
/ BX Tires going flat #23
Ha Ha! Tell the current price to do foam filled and how it makes the tires solid for such a comfortable ride. :D:laughing::cool2:
Oh by the way, I badly bent the front rim on my L3901 a couple of days ago and after beating it back into almost round with a sledge hammer it still won't hold air so off to the tire shop and have a tube on order and left the tire for pick up next week. I have a full gallon of Slime and a partial gallon of Slime left from using it on the front tire on an old deck mower on my former F mower, the tire was cut in a few places after falling off and being run over and cut a bit so nothing to lose by Sliming it.
I know the issue with the BXs is most probably the tire spinning on the rim so I say use tire sealer first if a air bubble under water can not be found. If a holein tire then plug it is what I've done to a few over the years. I've used all methods except foam filling and researched doing that and concluded the price was way to much and some people mentioned the hard ride with a solid tire.:2cents:
/ BX Tires going flat #24
another vote for foam filling. i was worried about the talk of steering linkage stress ect but have not found much concrete evidence on this. The quote i got from my local industrial tire place for BX front tires was $110 each, and each front wheel will weigh 49 pounds. not too bad. esp when you consider the front end is made to handle a FEL, front end weights ect, a few pounds on the front wheels wont bother me. no more flats. Ive heard several instances of tubes and rims becoming misaligned, dont feel like dealing with that.
Im going to get the fronts done this month (brand new tires already been plugged once). And when the rears eventually get punctured and blow out all their ballast, i will take those for foam too.
/ BX Tires going flat #25
Im going to get get the fronts done this month (brand new tires already been plugged once). And when the rears eventually get punctured and blow out all their ballast, i will take those for foam too.
So you don't have foam filled to tell about your experience using them already? Your just telling what your going to choose to do? You have no experience as to the ride of the BX with foam filled tires? I personally have had some concern about the cost but that wasn't totally a deal breaker but the past reports on ride quality of basically a hard solid tire concerned me. I've owned several BXs and the last one I bought rode so rough my wife and finally my grandson who loves to drive (Age 14) complained so much about the ride quality and I felt as bad or worse about it than them so it's now gone to my brother next door. Thanks for giving your price quote of $220 for the two front tires and I guess plus tax. If I had the constant thorn problem as some do I'd also do foam or cut the trees.
/ BX Tires going flat #26
sounds like you got it all figured out
/ BX Tires going flat #27
I don't have thorns to worry about. I suppose if I did... the foam option at 4 to 5 times the cost of tubes would be the better way to go.
/ BX Tires going flat #28
I had troubles with the front turfs on the JD 4010. First went with some Slime, then tubes and eventually replaced them with new tubeless. The replacement turfs seemed tougher. Never a problem with the turf rears.
Last 2 tractors have had R4s with absolutely no issues whatsoever. They're just rougher because air pressure is higher in them, and I think they're a stiffer tire.
Ralph
/ BX Tires going flat #29
Ralph
That could be... R4s being stiffer and such a lesser issue than turfs. I dunno.
/ BX Tires going flat #30
I've had R4s when I had a FEL and never had a flat on any of them. It was always that one turf on the front of the BX and often times it was erratic. Sometimes it would go weeks and never go down and sometimes it was days.
/ BX Tires going flat #31
I hope we hear from you AFTER you get those tires foam filled and use them a few times and give us a review of your experience.
/ BX Tires going flat #32
There were others about 10 years ago, (myself included), that had the front tires (turf tires) losing air on the BX models. It turned out to be the seating around the rim...right out of the dealers....brand new.. I fixed mine with some rim sealant that took care of the problem.
Cheers,
Mike
Yeah, ?9 BX2660. Constant flats on both front tires. After the first year put tubes in both, no issues since. Fortunately I don稚 drive it in an area with thorns or sharp items.
/ BX Tires going flat #33
I foamed both my R4 front tires on my M59 after too many times of dealing with flats or squishing with a loaded bucket. Thorns, nails, stump snags in brush piles, sharp shale, etc made it well worth the $400 it cost to know I can get another 10 years out of them without worries. They ride about 10% stiffer but the only time I can feel it is full speed 15mph on the road, or if I run square over a sidewalk curb where the bump is pretty stiff. Still worth it, plus it eliminates sun rot as a factor for replacement. I may do the same to the rears if I ever puncture them and have to replace the liquid.
/ BX Tires going flat #34
Just picked up my new set of BX front turf tires/wheels.
Ready for at least a couple years of flat free tractoring! $165 complete from my Kubota dealer.
Almost too pretty to install!
I will wait until I have a problem before I put them on.
Just re-tubed the offending culprit...
/ BX Tires going flat #35
Tried that. Didn稚 work. Also tried filling in the front tires with this black goop. Can稚 remember what it was, but the tire shop did it. Then, after a while I guess it ate through the sidewall of the tire, because both front tires blew and squirted that black poop all over the place. Finally just went out and bought a new set of tires on rims, and they explained that they are much better than the OEM tires. Haven稚 had a problem since, so I guess the quality control problem has been solved.
Do you remember the brand and model of tire you bought, and where you got them? Are they turfs?
/ BX Tires going flat #36
My first BX2660, no issues with turfs. Even the R-4痴 were fine for years. Now, my current BX2670 had issues the first year. Got fed up. Tubed them. Last month, one went flat. Dealer said 泥on稚 tube it. Seal the bead? So far so good. One tubed, one sealed. As soon as I can swing it, I知 getting a set of R-4痴. The turfs are good for grass, and grass only.
How did you seal the bead? Not familiar with that.
I have a bx1880 with leaky front left - might be the bead - but my riding mower with really small front tires and also my wheelbarrow frequently leak flat via the bead - drives me crazy.
/ BX Tires going flat #37
What are the standard front tires on a bx24/25 called. Are they R4's? Want to order new rim/tire but not sure what part # is required as they show several different tires. Emailed them but no repsonce.
Been battling flats/slack pressure/leaking on the front since new at 2008. Replaced stems two years ago helped as they were shrunk. Went with tubes 5 months back big help as on one front was leaking through sidewall. But then using bx24 hard clearing debris after a septic field repair.
Spun tire on rim and pulled tube stem right out of rim. Ordered more tubes to have a spare. Need to buy a spare tire/rim so I'll have a quick fix to prevent downtime as had to go to shovel and wheelbarrow. Fortunately was 90 % compelte with job.
Update: Found shop that is going to foam the flat tire. Hopefully that will be a more permanent solution.
/ BX Tires going flat #38
'Standard' could be R4 or 'Turf'. Depends on the tread design you want. There are other tread choices but these are the two most popular for the BX line.
/ BX Tires going flat #39
It might be a good idea to foam fill both tires on the same axle....and yes, properly foam filling the tires WILL be the solution.
Had my BX tires foam filled over a decade ago (maybe 15 years ago). Happy camper.
/ BX Tires going flat #40
Rim sealer comes in a can with a brush and just brush it around the edge of the rim.
POWELL / COLE 6R RIPPER (A63291)
POWELL / COLE 6R...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
