BX SNOWPLOWING SAFETY
/ BX SNOWPLOWING SAFETY #1
WALT
LOUDON NH
KUBOTA BX2200, L-39 TLB & RTV X1100C
I thought I would share with the group an incident that happened to me, and how to prevent future occurences.
When plowing my 450' driveway, I use a combination of the loader and my Woods LR106 6' rake with graderblade down.
I set the wheels to keep the blade 1" off the gravel.
The end of my drive, where the snow is pushed, is an approx. 70' drop to a brook, at a 60 degree angle. While dragging the snow with the rear blade near the edge, I moved the 3 point lever to raise the rear blade. Due to the large gloves I had on, I also knocked the transmission from low range to neutral.
The tractor rolled forward towards the abyss 2' until I realized what was happening and slammed on the brake. I had about 4' left before going over the edge. After identifiing my stupid error, I was much more careful completing the job.
I am not new to tractors or operating machinery, (650 hrs on the BX 2200) but as has been posted before, a few seconds of inattention can get you mentioned in this forum.
After some thought, I decided to somehow secure the transmission lever from being knocked into neutral again.
The solution was to make a T-shaped insert, that drops into the lever slot, easily removed, that secures the lever in high or low range. Using 1/2" plywood, the piece that drops in the slot is 7" long by 3" wide. A 1 1/2"
wide piece screwed on top keeps the insert from falling down.
Adjust the sizes to fit your tractor.
Hope this prevents any of you repeating my seat stainer.
HAPPY TRACTORING
WALT
/ BX SNOWPLOWING SAFETY #2
Walt I'm glad the story turned out well for you otherwise it may have been a wild ride indeed. Sounds like you have the right fix for your problem as well.
I am also thankful that some of the manufacturers choose to place the 3-point position control lever on the opposite side of the tractor from the range selector. Maybe they should all be like that? /forums/images/graemlins/tongue.gif
/ BX SNOWPLOWING SAFETY #3
The other nearly safety issue in my mind it the PTO level is on the left on the BX with the 3PH on the right.
If you are running a Post Hole digger, you have your right hand on the 3PH, looking over your right shoulder.
Need to stop the PTO--turn all the way around to the LEFT to reach that handle. I don't like it, but haven't
figured how to change it yet.
If anyone else know, please let me know.
Ron
/ BX SNOWPLOWING SAFETY #4
WALT,
Glad to hear you're O.K.. It sounds like you've got a good solution to the problem as well. My B2910 has the 3 pt. lift on the right side with the range selector on the left. I never thought of that as a "safety feature", but I guess it almost is.
Be safe /forums/images/graemlins/smile.gif.
~Rick
/ BX SNOWPLOWING SAFETY #5
Does pushing in the clutch disengage your PTO?
/ BX SNOWPLOWING SAFETY #6
I am not a huge fan of the neutral position on a HST tractor. I only intentionally put it in neutral because I have to to start it.
I have more than once found myself free-wheeling, unintentionally in neutral after first starting the tractor. Usually happens when I raise the FEL and weight block.
It takes a scary second to figure out what is going on and find the brake pedal again!
- Rick
/ BX SNOWPLOWING SAFETY #7
We had a fellow to dinner here not long after I'd just bought my Gravely (1987, like new with 104 hours on it). He told about mowing with a Gravely on a hill with wet grass. He was on the sulky. Seems it went to skidding down hill (him with his hand on the reverse bar) and kept going. This was on a golf course. He had an audience. Seems there were a couple trees at the bottom of the slope, just wide enough apart. He made it between them and finally came to a stop.
I had a similar experience going up hill not long ago that kinda prompted my desire to pursue getting a BX or similar for my birthday next April. I was climbing my 30% hill out back in high range with the Gravely on the sulky with cart hitched behind the sulky. It started spinning. So, I had to gear down to low range. Instead of just popping the lever in, I went through neutral on the other lever and didn't get my hand brake on. The sulky pitched me off on my back side, and the Gravely proceeded to look as though it was going to run me over. Fortunately, the whole thing jackknifed and just sat there sideways on the hill. I put it into 1st low and walked it up the hill.
Ralph
/ BX SNOWPLOWING SAFETY #8
PKS,
No clutch--it's HST. Even if it had a clutch, it should be live PTO, so that shouldn't affect stopping it.
THKS,
Ron
/ BX SNOWPLOWING SAFETY #9
Ron,
Maybe I'm missing something here, but are you sure about the "no clutch" statement? How do you change gear ranges or engage the PTO without a clutch?
On my B2910, the clutch stops the PTO from spinning and I bet it does on your BX too. When using the post hole digger, I will admit that the body is in a bit of a twist with my left foot ready to engage/disengage the clutch while my head is turned over my right shoulder watching as the bit is lowered. At the first hint of an obstruction, I step on the clutch to kill the PTO.
~Rick
/ BX SNOWPLOWING SAFETY #10
Rick Jay,
No clutch on the BX2200 HST. PTO engages with a lever on the left side. Right foot operates the HST pedal and the one brake pedal.
Left foot can depress the diff lock. Shift from Lo to Hi range by stopping (HST pedal to neutral), manually move Lo-Hi level to other range.
Works slick. To me a clutch would only be in the way (except for this PTO issue).
Ron
/ BX SNOWPLOWING SAFETY #11
My Gravely apparently does not have a clutch for the PTO. It seems to be gear-engaged. You have to slow down the engine speed to get it to go in. Otherwise, it's like shifting without a clutch and trying to get the standard trans into gear.
Ralph
/ BX SNOWPLOWING SAFETY #12
Ron,
Thanks for the info. I guess I just figured the BX's were just "mini-B's", but I guess this is another difference between the two series.
I can see why operating the PHD with that type of set-up is a bit of a pain. In fact, I would almost tend to feel that as a real safety concern as it would be difficult to quickly disengage the PTO should a "problem" arise. I wonder if anyone else on this forum has found a solution to make the PHD operation a bit easier on the BX's?
Take care,
~Rick
/ BX SNOWPLOWING SAFETY #13
Hi Rick,
That's one reason I'm not sure I want to dig many post holes. Getting cranked 270 degrees back around to the lever quickly doesn't seem too good.
The other thing I'm having trouble with is the PHD is SO CLOSE to the tractor, I have trouble lining things up. I'm used to a bigger tractor where the PHD is farther back, so you get a better perspective.
On my PHD also, the assist arm is about in the middle of my back! I plan to remove it, make a couple of 45 degree bends in it, and reinstall it out to the right some where I can reach it without being a Contortionist
/ BX SNOWPLOWING SAFETY #14
Ralph,
My old 812 Gravely has a clutch for the PTO. The PTO lever operates the clutch and engages the PTO without any grinding.
Is your Gravely an old real Gravely or an Airens Gravely ? I am not familiar with the 5xxx series.
/ BX SNOWPLOWING SAFETY #15
Mine's about a 1987 vintage Gravely. Don't know whether Ariens had them by then.
Ralph
/ BX SNOWPLOWING SAFETY #16
got to agree with u on this one , my b2400 has hydo and a clutch, putting in the clutch stops the pto, also the range lever is on the left and the 3pt lever is on the right.
/ BX SNOWPLOWING SAFETY #17
An alternative to the PHD being to close to the rear of the tractor would be to use the FEL QT and a post hole digger off of a BobCat mounted on your FEL and powered by your hydraulics instead. That way you would have good control & better visibility.
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
20704 (A55853)
20704 (A55853)
2019 CATERPILLAR 259D SKID STEER (A62129)
2019 CATERPILLAR...
2014 KOMATSU D61PXI-23 CRAWLER DOZER (A62129)
2014 KOMATSU...
832801 (A61166)
832801 (A61166)
