BX snowblower "oil level" question
   / BX snowblower "oil level" question #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
On the blower it says check the oil level before use, are they referring to the hydraulic oil in the tractor? Or is there a fill on the blower itself?
   / BX snowblower "oil level" question #2
On mine that refers to the gearbox oil on blower. Checking each time is, IMHO, overkill. Long winters here and I check three times. Never had to any oil.
   / BX snowblower "oil level" question #3
There should be a check hole on the gearbox of the blower, about halfway up the box.
Thanks guys
   / BX snowblower "oil level" question #5
I check and top off mine once a season, unless I see evidence of oil leaking (so far none). I use big truck hub oil and it works good. The containers even have the little cone shaped nozzle for stuffing into the little hole and squeeze the liquid in until it runs out.
   / BX snowblower "oil level" question #6
Do not forget to oil the chain on the blower, I used to do it every other outing. China saw oil is recommended, also check the tension on the chain.
   / BX snowblower "oil level" question #7
As to chain lube, motorcycle chain lube is probably the better route to go as it clings rather than flings, also designed for that sort of 'crappy' environment.
   / BX snowblower "oil level" question #8
Motorcycle chain lube and synthetic gear oil is what I use on mine. Surprisingly the chain don't collect much if any crud being behind the blower. Snow melt is probably the biggest concern.
   / BX snowblower "oil level" question #9
I think the manual for the blower calls for chainsaw lube. I do not have the blower or manual anymore since I sold my BX.
   / BX snowblower "oil level" question #10
I use tacky motorcycle chain lube on mine as well, just made good sense. Do not understand how chain saw lube could be better in this application. Also, running Mobil 1 80w-90 synthetic in gear box. Yesterday was my last mow of the season, snow blower is installed, waiting on the white stuff! Philip.
Rollback (A53117)
Rollback (A53117)
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2008 Honda Pilot SUV (A53117)
2008 Honda Pilot...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
