BX snow chains source
   / BX snow chains source #1
allthumbs23
Bronze Member
WI
Kubota BX2230
I have a BX 2230 with turf tires and am spinning alot on my gravel drive with the wet snow using the front bucket. Anyone have a source for tire chains? Thanks
   / BX snow chains source #2
tirechains.com tirechainsrequired.com Search button works well. :thumbsup:
   / BX snow chains source #3
May want to consider some type of rear weight even w/tire chains.
   / BX snow chains source #4
I've got the same tractor and tires. I have my rear tires full of washer fluid and I hang either a 275lb weight bar or 200 lb 5 foot rear blade on the back end. On my paved driveway, I have pushed snow hard enough to lift the front end off the ground and then had the rear tires squawk. Chains may help, but get weighted down first.
   / BX snow chains source #5
I did tirechains.com as well and it makes a huge difference
   / BX snow chains source #6
Try the local walmart or auto parts store . A set for a car could work .
You know what else would help? If I had put the **** thing in 4WD!! I was in such a hurry today to get the wife going I spaced on it. That's embarrassing....
   / BX snow chains source #8
you might check on e-bay also. think jd 1025r(not sure model #) uses same tire size as bx-series. I got mine for under $25/set front&back off season on e-bay even got a second set for rears but have not needed double chain in 4 wheel drive
   / BX snow chains source #9
We won't tell the wifey what you did! It happens to the best of us.
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
7022 (A50322)
7022 (A50322)
2013 CHEVROLET TAHOE (A53843)
2013 CHEVROLET...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
