BX replacement light switches
/ BX replacement light switches #1
UncleAl
Statesville, NC
'24 BX23
I finally got fed up with having to clean out my inferior "waterproof" BX light switches and found proper replacements. They're true "marine-grade" (IP66) and fit perfectly. The only concession was having to make short jumper wires to bridge from the turn signal connector to the new switch (or you could just cut off the connector and put disconnects on the wires).
They're Ancor Surf 'N turfs. You'll need 2 SPST and 1 SPDT. Best price I found was at wiringproducts.com, total cost with shipping about $21.
http://www.ancorproducts.com/whats_new/New_Products/homepage.html
/ BX replacement light switches #2
Looks good, nice fix. These OEM switches should have ever made their way to the dash of a tractor......
Volfandt
/ BX replacement light switches #3
Waytek Wire has similar switches rated waterproof and with illuminating capabilities. I bought some toggles with rubberized bodies and boots to redo my ROPs lights, but may opt for a series of four switches in a 4-switch "housing" to mount in the front of the dash beneath the key as I believe there is room behind for the business. The also have a waterproof fuse box I intend to replace that taped monstrosity with behind the air screen. In addition, they have a marine grade waterproof "cigarette adapter" plug that is waterproof capped and when a plug is inserted. I will switch this, my forward and aft lights and would like tio find a small strobe to mount on the ROPs for the fourth switch when using the backhoe.
http://www.waytekwire.com/
2014 CASE IH Magnum 340 AFS (A63111)
2014 CASE IH...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
GREAT PLAINS TSF1060 PULL TYPE SPRAYER (A64280)
GREAT PLAINS...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
HONDA WP40X 3" WATER PUMP (A64281)
HONDA WP40X 3"...
