Loader Bx quad FEL valve bottom replacement
   / Bx quad FEL valve bottom replacement #1
sandyc
Steep Falls, Maine
BX 2380
So I suffered as some with the leaking valve thing. I replaced the top four valves with summit female flat face valves. No leaks....worked great. Now I find the bottom valves are beginning to weep a bit. I can tighten the fittings but am tempted to replace the cheap Indian kubota oem with the corresponding summit male valves. I kind of think I’ll need to adapt the new valves to the hard lines on the tractor. If memory serves, I’ll need four adaptors, 3/8 jic x 1/4 npt.
Has anyone else done this? Any great problems?
Thanks for the help.
Got the flat face connectors and the adapters. Before I tear everything apart I’m going to try using thread sealant and see what happens. Probably should have done that first but at my age things tend to slow down.
   / Bx quad FEL valve bottom replacement #3
I use permatex pneumatic/ hydraulic sealant. Better than tape or goop with a brush.
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
300 GALLON SPRAYER TANK (A60430)
300 GALLON SPRAYER...
John Deere 3025E (A53317)
John Deere 3025E...
