BX Owners -- ANOTHER Front End Question
   / BX Owners -- ANOTHER Front End Question #1
Rimmer
Lower Ohio River Valley
Kubota BX23, Ford 8N
BX Owners -- how much side-to-side play do you have in your steering cylinder? Not in the tie rods, etc, but in the main rod that comes out of the cylinder itself?
I have noticed that mine has maybe 0.010" to 0.015" of play in it -- enough that I can actually feel it "clunk" when I shake the tractor from side to side with the FEL off the ground, or when I wiggle the front wheels, for that matter. You can actually see the seals moving with the rod. I called my dealer yesterday to ask if this was normal, and he came out today to look at it. He said he would check with a Kubota tech and see what the specs are, and if needed would install shim washers to take up the slack, or replace the whole cylinder if necessary.
BX23, 29.9 hours.
/forums/images/graemlins/tongue.gif
   / BX Owners -- ANOTHER Front End Question #2
Mine has a little more than 1/8 of an inch, It's almost like it's not "tight" in the mount, but there's no way to remove the play.
2015 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53473)
2012 RAM 5500...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2018 LAMAR TRAILER 40' T/A GOOSENECK TRAILER (A53843)
2018 LAMAR TRAILER...
1991 MACK RD600K HOT OIL UNIT (A53843)
1991 MACK RD600K...
