bx or zero turn
/ bx or zero turn #11
The BX can go fast but frankly, unless you have a real smooth lawn it will be a rough ride. I read one poster complain a while back about the BXs rough ride. Hey... it's a tractor, no suspension (for a reason). If you want a mower get a ZTR mower. If you want versatility... a BX.
/ bx or zero turn #13
You're not going to beat a specialized grass cutting machine with a multi purpose machine. Keep in mind that a MMM detracts somewhat from the versatility of a tractor.
/ bx or zero turn #14
Agree with above except if the ground is rough, you want big tires. As big as you can find and bouncy is good.
I pull a finish mower with an old M5400 in those spots that just beat the tar out of me on a ZTR. The wheels on the tractor are at least 3 times taller. I'm not sure a BX would be any more or less comfortable on rough ground than the ZTR.
/ bx or zero turn #15
I'm one of those people that are "against the grain" on this one. If I was in business it would probably be different, but as a homeowner that mows 2+ acres I will take a riding mower/mid mount mower any day. My father has a 54" zero turn and I have tried it numerous times, mowing while he is gone. It seems to beat the crap out of my lawn. Circles around the trees and on a slope, it just skins up the grass as I try to turn. Driver error? Maybe a touch, but I'm pretty comfortable with it as far as normal operation goes. I have noticed many other people that have them and have the same "rings" around the trees and same problems with the side hill problem. Basically for double the expense I would be hoping for better. As far as saving me time.....why are we in such a hurry for anyway? Just my opinion of course, but I will be having anything but a zero turn although I would like to try the ones with the mower out front and see if they are any different without spending the coin to find out otherwise.
/ bx or zero turn #16
grizzjeeper said:
I want your thoughts on what to do. I have roughly 3 acres to mow and am doing so with a cubcadet lawn tractor with 50 inch deck. its 26hp and only has a ground speed of 5.6MPH.. takes about 2 hours to mow lawn. Not a lot of trees but two Big willows and some big ditches near the road.
Borrowed freinds zero turn and mower complete lawn in under 1 hour. 48 inch deck but twice as fast.
I already have a kubota l3400 for loader work and backhoe work when i need it and its not normally stored at my home. Soo... I was thinking of a BX series with as large of deck as I can find? 72"? I know I will not have manuverability but figure with the larger deck it should offset the time? Plus I figure I can mow faster than 5.6 mph?
or should I just stick with the zero turn? Opinions please and feedback.
Be nice to have a smaller loader for the occasional chore istead of trailering the big boy over.
I'd go for the more versatile BX;besides what's the mowing hurry any how?
Take time to stop and smell the roses.;)
/ bx or zero turn #17
The biggest BX deck you can get is 60".
I faced the ZTR vs. BX question and you can see what won out.
I mow about an acre of grass in about 45 minutes. WITH grass collection. That doesn't include trimming, but I can get so close with the BX, I only trim every other or third mow.
A ZTR would mow faster, sure. But you can't do ANY of the stuff I do with my BX on a regular basis.
My cousin mows 5 acres and has a ZD21 ZTR. I'd MUCH rather have his ZTR in his situation...faster and more comfortable. The tractor can bounce you around a bit (sitting square over the wheels with a tractor seat vs. his spring-loaded setup). But he also needs a B21 on his property to do the "other stuff". I've combined both into one. And on my heavily tree'd 1 acre, I'd pit his ZD21 against my BX any day. I bet he'd get done about 5 or 8 minutes faster than my BX. Not worth the trade-offs in my book.
My two cents.
/ bx or zero turn #18
shrekbelly said:
i owned a commercial toro z master 100 w/19 kawasaki twin and a 52"sfs deck. outrageous manuverability, dangerously quick and gave me a superb quality of cut. alas, it was only a spring to fall machine.
i sold her and miss her, however i now own a bx1850. true- more money-
but a hughly more capable machine. i'm glad i switched over. you've got a tough decision--good luck with it. shrekbelly
A ztr can't be a tractor but a tractor can mow.
/ bx or zero turn #19
have_blue said:
You're not going to
*beat a specialized grass cutting machine with a multi purpose machine. Keep in mind that a MMM detracts somewhat from the versatility of a tractor.
*Why is it so urgent to beat it or even come anywhere near matching it anyway?
/ bx or zero turn #20
Dads got a jd455 w/ 60" cut, and about 4 solid acres to mow out of 10, lots of trees, ponds, hills, and piles of "stuff". best time on the 455 was just under 4 hours to do everything. I have a b3030 tlb , no mower, and a kubota zd326 60" diesel ztr. I just mowed the place today so he would not have to be out in the 100+ degree heat in just over 2 hours. A ztr is a mower and thats it, if thats all you want to do with it then its by far the best way way to go. I was a commercial operator and the diesel 26 hp 60" was by far the best way to go. i feel 60" cut is the biggest you should go to keep from scalping on uneven terrain. speaking of uneven only a ferris will give you a plush ride from what I hear mine will through you just about out of the seat at 12mph when you hit a big bump.
good luck and buy what YOU want !!!
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2007 Ford E350 (A55973)
2007 Ford E350...
2019 Deere 35G (A53317)
2019 Deere 35G...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2013 Club Car Carryall 252 Electric Utility Cart (A59228)
2013 Club Car...
