BX OEM QA/Forks vs. Tach n Go and Jery's Forks???
   / BX OEM QA/Forks vs. Tach n Go and Jery's Forks???
Not sure why it's not a good idea. Jery makes a ripper hook FOR his QA.
As for the eye, I'd rather pull from the center than the side, or off center.
Yeah I don't see an issue other than I would prefer a shorter moment arm so when lifting or pulling you don't put so much torque on the Q/A.
Decided to update this thread after following some other threads including going with clamp on bucket forks. If you go with this QA system you can get the forks on and off as fast as messing around with straps and hold down screws and do with no lifting!
Benefits vs. clamp on bucket forks... fare more lifting capability and no risk in bending your bucket. Highly recommend Jery's QA and adjustable forks!
   / BX OEM QA/Forks vs. Tach n Go and Jery's Forks??? #63
I agree. Jery’s setup is the best for CUTs, especially because it is so light.
Maybe one day...
   / BX OEM QA/Forks vs. Tach n Go and Jery's Forks??? #64
Just thought I'd chime in with a quick thumbs up for Jery's work!! I have his quick attach Tach-N-Go, his fixed forks, & his Loader Buddy for my Massey GC1720. Great stuff, great builds, and a fantastic guy to work with as well. Currently I'm working with him on a third valve/ram set up to use with his Minni-Grapple which mounts on my Loader Buddy. It will be nice to also have the same third valve/ram function for use on my three point top link. Will try to get some pictures up when it's all done, but IMHO, Mytractortools & Jery Dunn are the way to go!!
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2017 CHEVROLET 2500 HD (A50854)
2017 CHEVROLET...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2015 WESTERN STAR 4900 SF (GLIDER) (A50854)
2015 WESTERN STAR...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
