BX OEM QA/Forks vs. Tach n Go and Jery's Forks???
   / BX OEM QA/Forks vs. Tach n Go and Jery's Forks???
Not sure why it's not a good idea. Jery makes a ripper hook FOR his QA.
As for the eye, I'd rather pull from the center than the side, or off center.
Yeah I don't see an issue other than I would prefer a shorter moment arm so when lifting or pulling you don't put so much torque on the Q/A.
Decided to update this thread after following some other threads including going with clamp on bucket forks. If you go with this QA system you can get the forks on and off as fast as messing around with straps and hold down screws and do with no lifting!
Benefits vs. clamp on bucket forks... fare more lifting capability and no risk in bending your bucket. Highly recommend Jery's QA and adjustable forks!
   / BX OEM QA/Forks vs. Tach n Go and Jery's Forks??? #63
I agree. Jery’s setup is the best for CUTs, especially because it is so light.
Maybe one day...
   / BX OEM QA/Forks vs. Tach n Go and Jery's Forks??? #64
Just thought I'd chime in with a quick thumbs up for Jery's work!! I have his quick attach Tach-N-Go, his fixed forks, & his Loader Buddy for my Massey GC1720. Great stuff, great builds, and a fantastic guy to work with as well. Currently I'm working with him on a third valve/ram set up to use with his Minni-Grapple which mounts on my Loader Buddy. It will be nice to also have the same third valve/ram function for use on my three point top link. Will try to get some pictures up when it's all done, but IMHO, Mytractortools & Jery Dunn are the way to go!!
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
2011 Peterbilt 386 Sleeper Truck Tractor (A50860)
2011 Peterbilt 386...
2001 International 3800 4X2 School Bus (A50860)
2001 International...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2013 Freightliner M2 106 Water Truck (A50860)
2013 Freightliner...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
