BX normal Operating Temp?
   / BX normal Operating Temp? #21
RET,
In case your still working on this, one more thing I noticed with my BX2200! This weekend I helped a friend move a load of fill dirt from the front of his driveway to the back of his property - approx. 200 yards - because the ground was too soft for the dump truck to drive back. Because of the distance to travel, I ran the tractor at about 3/4 throttle for around 3 hours while only using the loader. My temp gauge stayed at the 11:30ish position the entire time. When I was finished, I went home to cut my yard. While mowing, the gauge moved up and stayed at approx. the 1:00 position. Same day, same 94 degree heat, just different tasks and loads on the engine caused the change in the gauge - at least thats what I believe.
Scott,
No, I haven't done any further troubleshooting. But, my observations still agree with yours....11:30 position during general work and ~ 1:00 when mowing.
Even after mowing for ~2hrs at temp. position of 1:00, I can still grab and hold onto the radiator hose for several seconds and it only has a small amount of pressure on it (I can still squish the hose fairly easily)...so my touchy-feely temperature measurement system tells me it is not all that hot.
Thx!
ret
2016 INTERNATIONAL DURASTAR 4400 (A58214)
2016 INTERNATIONAL...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
1999 Peterbilt 379 Tandem Axle Road Tractor (A55272)
1999 Peterbilt 379...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
