bx MMM wing nut/knob
   / bx MMM wing nut/knob #1
Tractorrr
TN
kubota bx 2370-1
I keep losing the wing nuts/knobs and the washer that hold the MMM belt cover on. Any tips on how to keep these from coming off? I assume they are rattling loose. I think I've lost 3 or 4 in the past year or 2. You would think I would start finding them in the yard. I may just try to find a regular nut to replace them with this time. Anyone else have this problem?
   / bx MMM wing nut/knob #2
I’ve lost at least one of mine. I replaced it with a nut a washer.
   / bx MMM wing nut/knob #3
Get some LockTite. Not sure which color is for light duty, but that will do the trick.
   / bx MMM wing nut/knob #5
If you boooger up the threads on the NUT ( they are Brass) a little, the nut wont vibrate loose.
Use a pin and hammer to flatten out a couple of threads, that should be enough.
Cheers,
   / bx MMM wing nut/knob #6
Was over thirty years ago we used a rubber like paste on the thread, it didn't set but it stopped nuts rattling off, it may well be a Loctite product.
You could always drill a hole in the 'wing' on the nut and attach a wire to tether it so it doesn't get lost, I have done this on some of my yacht fittings swaging on a 1mm wire.
2342 (A58376)
2342 (A58376)
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Zero Turn Mower (A55853)
Zero Turn Mower...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
