BX log splitter?
/ BX log splitter? #1
Tdog
Platinum Member
SE Louisiana
BX22
I'm going to show some real ignorance here - - - I know that there are log splitters that can be run off of tractor hydraulics. Is there such an animal that a BX 22 could run?
I need a splitter, but don't want to maintain another seldom-used gasoline engine.
Thanks,
Jack
/ BX log splitter? #2
From what I learned from prior discussions here, the limiting thing is the flow rate. 5+/- GPM equates to very long cycle times for the splitting ram ... maybe 30 sec or so. An add-on PTO pump could mostly fix that though.
Cheers!
/ BX log splitter? #3
I have also noted on TBN that a log splitter with its own engine can be had for a very low price. Almost as low as one made for a tractor without the gas engine. It's not like the little gas engine is super high maintenance. Try northern tool for the splitter on the 3ph.
/ BX log splitter? #4
I went through the same debate and went with a 3pt powered by hydraulics of tractor on my L3010 Kubota (7gpm). I don't have the splitter on yet, but i kinda regret that route, as I had to spend a bunch on the valve kit to run the splitter, although I now have rear
hydro for my top link etc. I went with tractor unit as I would rather
hear the diesel than a loud Briggs gas engine. However, when you consider the valves, the gas units are cheaper and it sounds like they run faster. I went with the Ramsplitter, available direct or on eBay and it is a very well made American unit. It did cost less than the Northern Tool, but it has gone up $200 in the past
few months, mainly due to shipping costs. But you get to talk directly to the guy that makes it and he does ship "free."
/ BX log splitter?
Thanks for the info, all. Looks like I'm going to be hearing the put-put of a gas engine - - or maybe I'll rent. I'm still arguing with myself.
Jack
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2018 Bomag BC572 Articulated Refuse Compactor (A64553)
2018 Bomag BC572...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
2016 Isuzu NRR Elgin Broom Badger Sweeper Truck (A64556)
2016 Isuzu NRR...
2007 Polar Dot 407 Insulated T/A Chemical Tanker Trailer (A64194)
2007 Polar Dot 407...
