Schultz
Thought I'd pass on a deal I found and parts that turned out to be better than stock for my BX2200.
While plowing snow on my driveway with the rear blade, I caught the edge on a large frozen rock in our turn around. The rock didn't move and it snapped the three point link that keeps it from swaying into the tire.
After a quick internet search I found surplus parts at Burton Surplus Center. Type Kubota in their search and you will see all their Kubota stuff. The parts weren't exactly the same but they appeared to be Kubota parts. Maybe they're the new BX part. The link was about an inch or two longer but was a little thicker so it should hold up better, but it did adjust back to the exact spot I had it. I bought a pair for $8 and while I was at it I got the lift arms at $18 each, since I bent one last summer. These are also not exactly the same but will work perfectly. In fact better, since they're about 2-3" longer and 1/4" thicker, which will lift the blade a little higher in the air and resist bending a little better. The lift arms defiantly need a paint job since they were all scratched up and had paint cracking off. No rust though so they will work great after I bead blast and paint them. New OEM Kubota arms are over $70 each.
